Breaking my cossie :( - With prices and pics!!
Old Aug 18, 2006 | 06:08 PM
SapphyMike's Avatar
SapphyMike
Default Breaking my cossie :( - With prices and pics!!
Well, having just lost a job, i need to get rid of my cossie, and as its already in pieces as i've sold bits of it off to buy other bits, breaking it seems easier.
J Reg Black 4x4.
Engine is sold
Lambda sensor - SOLD
T3 Turbo - SOLD
3 bar map sensors - £40
4wd Exhaust manifold - SOLD
4wd Mongoose exhaust - £140
Bailey Cam cover breather kit - SOLD
4wd cossie ancilaries - PAS pump, Alternator, Waterpump - £25 each
Radiator and fans - £40
4x4 gearbox - £130
front and rear diff (good cond) - £50 for front, £125 for rear
Leather interior - £250
Cloth interior - £60
4wd inlet manifold / plenum cover - SOLD
PF09 TPS - £30
4wd Koni suspension -£150
4x4 Bonnet - £125
side skirts - £40
damaged rear bumper - Offers
front bumper (needs the brackets) with damaged fibre glass RS500 spliter - Offers
Raven hooded dash - £30
Electric Sunroof - SOLD
170mph clocks - SOLD
ABS Ecu - £10
Greddy Turbo Timer - £40
front grill - SOLD
fuel pump - SOLD
fuel tank - £30
Front 4wd brakes - SOLD
rear 4wd brakes (for vented disc's) - £offers
Front 4wd prop shaft - £15
2x rear 4wd prop shaft - £30
front 4wd hubs - SOLD
rear 4wd hubs - £50
rear arms - £40
rear 4wd beam - £50
4wd throttle body - £30
4wd cossie steering wheel - £25
Very good condition, looks nearly new, 4wd cossie steering rack - £40
4wd front / rear drive shafts - Fronts SOLD
boot spoiler - £25
Black J Reg Shell, not HPI clear, needs new front bumper bar welding in - offers
K&N Panel Filter - £10
Silver Dumpvalve thing - SOLD
ABS Pump - SOLD
4wd Heat Shield - £10
L1a ECU - £60
Green Top Cam Cover with breather spout - £50
2wd head, been heavily skimmed, suit n/a engine, complete with cams, valves, tappits - £200
AutoGauge Boost (psi), Oil Pressure (psi) and volts gauges - these are black faced and are black when turned off - SOLD
Boost gauge lit up
gauges in their boxes
Nearly new 4wd starter motor - £50
4wd thermostat housing - SOLD
4wd Waterpump, good condition, no play - £25
Black Carpet - £30
V Belt bottom pulley - £50
Dizzy - £30
4wd Engine loom - SOLD
Front antiroll bar - £15.00
rear anti roll bar - £10.00
headlights - £20.00 pair, £12 each
rear lights - £25.00
number plate surrond - £20.00
If you need pics of stuff, ask me.
should have pics for leather and cloth trim this weekend.
07852 165872
Old Aug 18, 2006 | 10:40 PM
Ben M's Avatar
Ben M
Default dump valve
hello mate is dump valve good workin order and is it a biddy scarer?
Old Aug 19, 2006 | 01:35 AM
SapphyMike's Avatar
SapphyMike
i couldnt tell you mate as it was just given to me as part of the car.
Old Aug 19, 2006 | 07:49 AM
Mr RS500's Avatar
Mr RS500
Mike
I will have the front shafts and front hubs, how do you want paying ??
Paul
Old Aug 19, 2006 | 08:40 AM
AlexD's Avatar
AlexD
Post Miester !
you have pm
Old Aug 19, 2006 | 10:32 AM
Csm's Avatar
Csm
Pm'd ya
Old Aug 20, 2006 | 05:35 AM
R5FORD's Avatar
R5FORD
pm sent
Old Aug 20, 2006 | 08:55 AM
lammylama's Avatar
lammylama
what housing is on the T3 mate.......if its a .63 i dont suppose you would like to sell it seperatley would you coz i need one asap to finish my build.
thanks
Old Aug 20, 2006 | 10:34 AM
tsrtrocse's Avatar
tsrtrocse
what injectors have you taken out? after a set of stabdard blues?
Old Aug 20, 2006 | 09:31 PM
hallen666's Avatar
hallen666
Hi, is the front grill the standard one? i.e with the ford badge in and does it have all the clips still in good order?
Thanks Mike.
Old Aug 20, 2006 | 11:11 PM
tregmatt's Avatar
tregmatt
u have pm mate
Old Aug 22, 2006 | 08:20 PM
SapphyMike's Avatar
SapphyMike
bttt
Old Aug 22, 2006 | 08:40 PM
Csm's Avatar
Csm
Did u ever get the piccy of the heat shield for me ???
Thanks
Old Aug 23, 2006 | 03:26 PM
Altratz's Avatar
Altratz
Hi im after a glove box as the handle is broken on mine also need the plastic gear stick surround i dont require the window switches if you have them and a price would be good regards Alex.
Old Aug 23, 2006 | 03:46 PM
Mr RS500's Avatar
Mr RS500
Mike
no answer or pm
Old Aug 23, 2006 | 09:45 PM
rstoughy's Avatar
rstoughy
Hi Mike,
I will take the water pump if you still have it let me know
Old Aug 24, 2006 | 12:30 PM
Gavin E-Cos's Avatar
Gavin E-Cos
Interested in the ABS pump, please PM me.
Thanks,
Gavin
Old Aug 24, 2006 | 07:37 PM
mondeomark's Avatar
mondeomark
From: Newcastle-under-Lyme, Stoke-on-Trent, Staffordshire
pic of front bumper and splitter please
Old Aug 25, 2006 | 09:45 PM
louie1's Avatar
louie1
how much for the shell with doors?
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
bigryrs
Mar 28, 2016 09:11 PM
Oct 9, 2015 07:38 PM
gcfcos
118
Aug 18, 2015 05:53 PM
Churtz
Aug 3, 2015 08:19 PM
