Frst fuel pump
Old Aug 16, 2006 | 09:22 PM
KnoxyGtt's Avatar
KnoxyGtt
T34 just kicked in Yo
Default Frst fuel pump
1st post
iv just learned that the fuel pump on my fiesta has had it, some folk have said that in order to take it out the full tank must be dropped, also can a cossie fuel pump be fitted or am i best off with the std one, if the cossie one can be fitted wot is needed for it to fit
cheers
ian
Old Aug 17, 2006 | 09:42 AM
JasperJ's Avatar
JasperJ
Welcome
The easiest way is to drop the Fuel Tank from its mountings as the hole under the back seat is not big enough for access. (check 1st tho as some people butcher the floor to it).
Escort cosworth Standard fuel pump is the one to use-but only if you intend to tune /modify your car, if not the standard one is fine, be sure its an RST one tho as the XR2i one isn't the same.
Old Aug 17, 2006 | 01:00 PM
KnoxyGtt's Avatar
KnoxyGtt
hmm, ill take the tank out tonight then see about getting a fuel pump, was just thinking it would be better to fit a cossie one if its easyer to come by plus it mean i wont have to do it in the futur when i start speing money on tunning it
Old Aug 17, 2006 | 01:08 PM
SafeChav's Avatar
SafeChav
Welcome to PF
Indeed the tank has to be dropped its part of the sender.
You can buy uprated ones specifically designed for the FRST, and im fairly sure it is a direct fit replacement.
Old Aug 17, 2006 | 01:11 PM
KnoxyGtt's Avatar
KnoxyGtt
i had alook on ebay ther and ther one going new for like Ł79 or somthing, then thers an uprated escos one for Ł89, im quite interested in the cossie one or just a std cossie one, wot are they like to fit, is it more or less the same as the fiesta one, if its alot of hassle i guess i would be better thr the fiesta one as it will be on the road soon again
Old Aug 17, 2006 | 01:59 PM
DUDE_SWEET_FRST's Avatar
DUDE_SWEET_FRST
standard escos will be fine mate
dropiing the tank is a pain in the arse cut the hole in the floor so you can get it out, much easier
so much so, ford redesigned later fiesta to have a bigger hole as to do this
Old Aug 17, 2006 | 02:10 PM
KnoxyGtt's Avatar
KnoxyGtt
cool, ill have alook on the cossie section for a fuel pump, going to drop the tank tonight, its been sunny and warm all week and now its just started raining , typical
Old Aug 17, 2006 | 04:19 PM
Oranoco's Avatar
Oranoco
It's only 4 bolts to drop the tank. I walked away fro 2 FRST's as the floors had been butchered to change the pump. It's not a hard job to do it properly, some people are just too bloody lazy to do the job properly.
Old Aug 17, 2006 | 04:26 PM
SafeChav's Avatar
SafeChav
I agree.......never done it on a fiesta but its not that dis-similar from an Escort.
Get the arse end up on some ramps and make sure the tank is as empty as can be, and its easy peasy
Old Aug 17, 2006 | 11:19 PM
jayRS's Avatar
jayRS
a guide i done on fiestaturbo.com mate
this guide was done for help for a guy that needed it on his xr2i, but its the same for frst also.
the fitment of the pump is the same for all EFI's and CFI's
Before starting any work make sure you have everything your going need to do the jon.
These are the bits I recommend to have or can get very easy (like the same day) to do these jobs.
Fuel pump
New sender unit sealer ring
Copper grease (for when fitting new bolts)
Spare nuts and bolts and washers
WD40
Something to syphen petrol from tank and store it in (if needed)
Jack
Axle stands
Tools
Injectors
New seals 8 for injectors, 1 for regulator
Fuel filter (if your changing it)
WD40
Tool
Rags to soak up petrol
First off you have to depressurise the system, even if your doing 1 or the other, to do this, take the fuse out for the fuel pump, take petrol filler cap off and crank it over a few times, disconnect battery.
you can leave the cap off if you want but don’t need to
make sure you have very little petrol in the tank, if there’s a lot your have to syphen it out other wise your spill it everywhere.
Jack and axle stands are need to gain more room under the car, you don’t need to raise it if you fell you have enough room, but I recommend to raise it a bit, even if you put breeze blocks under the rear wheels that’s a extra 3 inches.
But chock the front wheels, and make sure its safe to go under before you do.
If you plan to have the back high, and not remover the tank from under the car you may need something to rest the tank on save strain on the plastic fuel lines
fitting the pump
Disconnect the wiring plug from the top of the tank but lifting the rear seats and unplugging it.
To drop the tank, you need to disconnect all the pipes from the filler pipe to the tank, some have to be done once tank id off, and the tank can be slid off the filler pipe it self.
Undo the 4 bolts holding the tank up, you may find the back ones will be a pain, sometimes the spring nut snaps so it spins but you can get a spanner of it or wedge a screw driver in to stop it, but once all 4 are off lower the tank, front end first and slide it off filler pipe, if the whole tank is to be removed from under the car disconnect the remaining pipes from the tank.
To remove the fuel pipes from the sender unit, start with the one with the push fit connection, the outer white bit needs to be broken off (unless you have the tool) and you push the small inner white bit in and slide the pipe off as its no different to any other push fitting.
Remover the other pipe and now you can remove the tank from under the car.
If you don’t want to remove the tank from under the car, leave the 2 fuel pipes on the sender unit and proceed to remove the pump taking car not to kink or crack the fuel lines.
To remove the pump you have to get the whole sender unit out, using a bit of alloy or something (not steel as you don’t want to cause a spark!!!) tap the seal ring round and remove it, pull the sender unit out.
f you want to by pass the black box, cut the red and black wire that’s goes to it and join it the the wires to the pump. (you do not need to bypass this black box if you don’t want to!)
depending on the make of pump the connections could be different to that of ford but the plug for the new pump will/should be with it so good enough. but use protective connections with the plastic on them.
Remove the old pump from the sender unit, careful not to bend the float to the sender, you will need to keep the throttle damper for the new pump so fit that on the new pump.
fit the pump in the cradle and put it back reverse to how you took it out., check the bag at the bottom of the pump is not going to in any way touch the float on the sender , if it does, move it as it will tell you have fuel when in fact you haven’t! As it will keep the float up a little.
before you final fit the tank back, get a mate to fit the fuel pump fuse back in and turn the ignition on (with battery connected of course) to check the pump will prime/work, if it does refit everything in reverse to how it came off, if it don’t, check the fuse, check the batter is connected right, check the sender/fuel pump plug (give it a little wd40if need be) also check the fuel cut off switch which is located in the passenger footwall behind the kick trim, pull the plunger/switch up (off) and press it back down (on) as you want it on, if it don’t come up when you pull it, it means it tripped and just press it back down. if it still don’t work and your getting power to the pump then the pumps naff, but chances of that.....not likely
on the seal that the filler pipe goes into, rub a bit of oil over it to ease fitting the filler pipe back in, only a little will be needed and you can take a drip from the dipstick if you don’t have any spare.
injectors,
going on that the system is de pressurised and battery is disconnected and fuel pump fuse is back out,
you can do it with the top half of inlet manifold on (hard way)
or with it off (easy way)
for ease you can remove the top half of the inlet manifold but a new gasket is recommended for it if you do it this way and I also recommend new injectors seals 100% (if new injectors are fitted new seals should be with them, but get a new one for the regulator just in case)
disconnect throttle cable, do this by opening it by hand on the right side and removing cable, then prize it out with a screw driver from the bracket,
Unplug the TPS plug , the ISCV plug and also the sensor plug on the right hand side of the inlet, remove charge carrier/intake
you will also need to remove the vac pipe that goes to the brake servo, this is done the same way as the fuel pipe, push the little ring part in and pull the pipe out as that to is a push fitting.
there are about 4 nuts along the top back edge of the inlet, remove them, the other ones hold the injector loom on and they have to come off anyway.
depending on which bracket you have holding the throttle cable you might need to remove this, if its one that has a bit going down to the bottom half of the inlet, your need to remove 2 bolts either side of the throttle body, don’t worry if the bracket don’t move as its has another done below but that can stay, if you have a different one like most xr2is, its bolted to the top half only so you don’t have to touch it.
remove the top part of the inlet manifold, unplug all the injectors, and unplug the injector loom and remove (there is a plug that goes to the water temp sensor on the bottom of the inlet that has to be unplugged, and also the wire to the oil pressure switch also so you have to get you hand down the back but this one is just pushed on and pulls off.
just don’t forget to reconnect these when you put it back together
undo the 2 bolts that hole the fuel rail down, and pull off, it will be hard as the injectors are in it but it will come off.
you do not need to remove the fuel pressure regulator, if you do I advise a new seal for this also.
pull out any injectors that ate still in the bottom half, fit the new seals to the new injectors, I advise a dab of oil on each seal to ease fitting it to the injectors but more so to help back into the bottom half of inlet, if you don’t use oil its a focker!
fit injectors in bottom half, refit fuel rail, make sure all injectors have seated right (as far in as they will go) and bolt on fuel rail
from now, fit everything back on as it cam off fitting new gasket to inlet manifold middle, to get what’s left of the old one off you might need to scrape it with a Stanley scrapper/Stanley blade.
when it comes to fitting the vac pipe from servo back on this will just need pushing on like the fuel pipe, it will go so far and stop, that means its on and that’s finished with.
once its all back together, reconnect battery, put petrol in (if you haven’t already) fit fuel pump fuse and prime the system by turning ignition on and off a min of 6 times, turn it once so pump buzzes, when it stops do it again, don’t try and start the car until its primed!!
if you don’t want to do the easy way and you want to leave the top half on, then you have to follow what is above but don’t remove the top half, but I recommend the easy way!
if your going this far, why not replace the fuel filter.
if so, its located on the passenger side inner wing by the battery, leave it in the bracket but undo the bolts both ends as there be tight, once "cracked" you can remove the filter or take the pipes off first, don’t lose the copper washer that sits between the bolt and filter (both ends)
take filter out, fit new one and bolt pipes back on.
if fuel filter is replace I recommend the system is primed a lot more like 12+ times to ensure fuel is up to the injectors.
Please note, the way I have said about priming the system is right, you do not need to disconnect any pipe to bleed air out.
when you come to start it (even if you didn’t replace fuel filter) it might crank for a while but it will go, if not check all plugs on injectors and TPS etc etc, if need be spray the insides of the plugs with some wd40 and it will probably idle a bit funny to start with but it will/should settle back to norm give or take.
Again, if you think you cant complete this job on your own or do it safely, DON’T
Get someone to help you or do it for you.
But I strongly advise new injector seals are fitted, don’t chance the old ones, ive seen people fit them back despite what ive told them and they have leaked, and your hot exhaust is only 2 foot away, you want to take that chance for the sake of 20p per seal?? (Ł8 set from fords not including regulator)
Good luck and hope this guide helps.
Oh and the guild for fuel pump fit fitment is the same for all EFI’s and CFI’s.
Old Aug 17, 2006 | 11:23 PM
SafeChav's Avatar
SafeChav
jayRS calm down
Old Aug 17, 2006 | 11:31 PM
jayRS's Avatar
jayRS
Old Aug 19, 2006 | 03:26 PM
turtleturbo's Avatar
turtleturbo
Hello,
Question i'm fitting a cossie pump in my FRST. Can somebodyplease tell me, do i need to fit the trottle damper( on the pic), because i don't know what that thing is or what that thing is doing?
Old Aug 19, 2006 | 03:37 PM
SafeChav's Avatar
SafeChav
Be best to fit it, it smooths out/dampens the pulsing in the fuel lines caused by the injectors opening and closing
Old Aug 19, 2006 | 03:46 PM
turtleturbo
Do you mean it prevent a sort of vacuum or something? What wil happen if you don't fit it?
Old Aug 19, 2006 | 03:57 PM
SafeChav's Avatar
SafeChav
No, the fuel line, fuel rail etc is pressurised with fuel, as each injector opens and closes you obviously get variations in the fuel pressure, the damper helps smooth these variations out and also prevent noise in the fuel lines and so forth.
Its common when they go faulty to get noises inside the car as a result.
Old Aug 19, 2006 | 04:18 PM
turtleturbo
ok thnx mate cheers
Old Aug 19, 2006 | 04:42 PM
Oranoco's Avatar
Oranoco
Bin the black box out though as the current draw of the Cossie pump soon fucks it. Ask my brother as I had to tow him home when his went tits up
Twice I've had to tow him home now with pump related problems. 2nd time it was a faulty inertia switch.
Old Aug 19, 2006 | 08:36 PM
KnoxyGtt's Avatar
KnoxyGtt
i managed to get the tank off, the 2 front bolts where piss easy bit the back ones just kept spinging, tryed to put a spanner on the nut but it just ketp sliding off , and up grinding it off , need to go to ford to get some new ones me thinks, question is how do i take the pump off the sender unit, it seem to be pluged in at the top it supported at the botton with some plastic think with the mesh bag beside it, dont want to force it down incase i break something, and also is anyone elses fuel gage really really crap, mine gose up and down like a bitch
Old Aug 19, 2006 | 11:57 PM
jayRS's Avatar
jayRS
the bag part does come off, but just pull it through the cradle, and pull the pump and throttle damper off, its only puhed on
Old Aug 21, 2006 | 12:19 PM
KnoxyGtt's Avatar
KnoxyGtt
ok iv now got it off, put it up to the car battery and it runs fine, but when i put i back on the car its still not going, is ther a fuse or realy that i could check, other than that i would run a live feed to it but i want to keep the car the way it was ment to run tbh
Old Aug 21, 2006 | 12:26 PM
SafeChav's Avatar
SafeChav
Sounds like your inertia switch needs resetting, i'm not actually sure where they are on fiestas though
Old Aug 21, 2006 | 12:31 PM
SafeChav's Avatar
SafeChav
Passenger side footwell, behind the plastic trim
Old Aug 21, 2006 | 07:15 PM
KnoxyGtt's Avatar
KnoxyGtt
aaargh this is going to be a never ending story with this car, got the fuel pump working fine, however when i fired up the engine it sounds like a bag of nails, it sound like a 1.1 fiesta, really really really tappaty , dont want to run it incase it lockes up on me or somehting
Old Aug 21, 2006 | 07:18 PM
SafeChav's Avatar
SafeChav
Was it the inertia switch?
Check the oil level, and if its ok, start it up and let it get warm, i'd 99.9% guarantee the hydraulic lifters have lost oil while its been sat, it will be fine
Old Aug 21, 2006 | 07:20 PM
KnoxyGtt's Avatar
KnoxyGtt
just spoke to a guy and he thinks that because that the car has been jacked up from the back the hydro lifters have been empted, he says to drain the oil and put good quilty stuff in, anyone else herd of this also
Old Aug 21, 2006 | 07:22 PM
KnoxyGtt's Avatar
KnoxyGtt
well, all i did was cut the wires from the black box and put them righing onto the pump and it runs fine for some reason, guess it will do untill i get the full pump assembly
Old Aug 21, 2006 | 07:36 PM
SafeChav's Avatar
SafeChav
You shouldn't need to change the oil.....thats a bit extreme but you can never change your oil enough.
As i said as long as the oil level is ok start it up and let it idle up to temperatuire and i think you will find by then its stopped tapping.
And the inertia switch...........just leave it, they are a pain in the arse. Im sure they are resetable on these aswell but none the less its one less thing to play up if its removed
Old Aug 21, 2006 | 08:07 PM
KnoxyGtt's Avatar
KnoxyGtt
yeah, its crap oil in it anyway, its burning some at the mom so i just got a cheap tub to top it up now and again, but ill get proper good stuff tomorow
Old Aug 21, 2006 | 08:18 PM
SafeChav's Avatar
SafeChav
No point buying good oil if its burning it..............
Old Aug 22, 2006 | 07:37 AM
SassyRS's Avatar
SassyRS
Little Miss...
Anyone that pulls back the metal from within the car to get to fuel tank needs shooting...
Old Aug 22, 2006 | 11:16 AM
Lou Lou.'s Avatar
Lou Lou.
Old Aug 22, 2006 | 03:39 PM
Oranoco's Avatar
Oranoco
I feelt the same but yet got told I didn't know what I was on about on FT when I said it was a bodge
Old Aug 22, 2006 | 04:23 PM
SafeChav's Avatar
SafeChav
anyone that does something like that........
2 words...........
ROUGH CUNTS
Old Aug 22, 2006 | 04:28 PM
jayRS's Avatar
jayRS
i know what ya mean some think its ok, well i guess it is ok, i done it to a mates car, wasnt happy about doing it but he told me too sa he couldnt be fucked with the hassle of dropping the tank, even though i was doing it
i have never and would never cut the floor, if i was buying a fiesta now, i would lift the rear seat, if floor was cut i would expect a drop in price from the car.
Old Aug 22, 2006 | 04:36 PM
GUZZLER's Avatar
GUZZLER
i shouldn't think the Ford tech department would take to hacking through the floor to get to the pump
i was thinking of getting a plate made up for Sassys car to make a proper inspection cover after making the hole a bit bigger in a professional manner.
Old Aug 22, 2006 | 04:44 PM
jayRS's Avatar
jayRS
thing is though, the hole isnt there for the pump to come out, its there for the plug, if ford had only mad it just a little bigger from standard......
Old Aug 22, 2006 | 04:49 PM
SafeChav's Avatar
SafeChav
As Oranoco has said on later fiesta's the hole was enlarged for this purpose.
The only time i would ever consider cutting the floor to do this is with the tank off anyway, to make a nice neat job of it and to properly paint it all after.......anyone that attempts to hack away at metal with power tools above a petrol tank is clearly not a deep thinker
Old Aug 22, 2006 | 05:42 PM
Oranoco's Avatar
Oranoco
Saw one car and it had just been hacked with snips and then folded back and then bent back afterwards and taped up with Duck tape
Guy looked gutted when I said no thanks.
Old Aug 22, 2006 | 06:17 PM
SafeChav's Avatar
SafeChav
Pfffffffffft, thats the sort if thing i can't stand
Did the guy know or did you bring it to his attention?
