bit of help needed
Old Aug 16, 2006 | 07:57 PM
craig rs's Avatar
craig rs
Default bit of help needed
ok i recently decided to remove the abs from my s2, as the car had a underbody resto through the winter there is no breaklines anywhere on the car, now i have got full braidied break lines which im going to be using, but on the rear of the car i dont have the compensators ( circled in pic ) now do i still need to have these or can i just take the braided hose to rear calipers ???? any help will be appriciated
Old Aug 17, 2006 | 12:01 PM
SafeChav's Avatar
SafeChav
You can run the pipes straight to the calipers but you MUST have fixed rate compensators under the bonnet!!!!!!
Old Aug 17, 2006 | 12:05 PM
craig rs's Avatar
craig rs
so basically it would be just as easy to have them in there original brackets on the rear
Old Aug 17, 2006 | 12:15 PM
SafeChav's Avatar
SafeChav
No because they are pants And also make bleeding the brakes a little harder.
Look on any NON ABS car and you will find a set of the in-line compensators
Old Aug 17, 2006 | 12:20 PM
craig rs's Avatar
craig rs
cheers dude know anyone that might have sum for sale
Old Aug 17, 2006 | 12:21 PM
SafeChav's Avatar
SafeChav
I could probably get you a set from the local scrappy if you are really that stuck for them
Old Aug 17, 2006 | 12:25 PM
craig rs's Avatar
craig rs
what models did`nt have abs? i will look in the scrappy later
Old Aug 17, 2006 | 12:30 PM
SafeChav's Avatar
SafeChav
All RS's had it (not that you find them down the scrappy anyway ), but any model below a RS came with or without as an optional, you will find the majority of XR3i's don't have ABS, and i've never seen anything less than a 3i with ABS although it was available as an option for all models
They're located on the drivers side inner wing
Old Aug 17, 2006 | 12:36 PM
craig rs's Avatar
craig rs
cheers m8 will av a look, if i struggle to find sum i`ll give ya a shout if thats ok
Old Aug 17, 2006 | 12:38 PM
SafeChav's Avatar
SafeChav
Yeah thats cool
(don't fancy going down there today anyway its wetter than a mermaids muff )
Old Aug 17, 2006 | 12:42 PM
craig rs's Avatar
craig rs
true tis here aswell but all in the name of fun and that, just take the old ladys brolly wiv me
Old Aug 17, 2006 | 12:59 PM
SafeChav's Avatar
SafeChav
Pffffft treading on thin ice
Old Aug 17, 2006 | 03:55 PM
I have used the ones of a ka on mine and mounted them inline on the braket on the rear chassis rail
Old Aug 17, 2006 | 04:28 PM
SafeChav's Avatar
SafeChav
And those inline ones can also be found on MK5 & 6 Escorts and Mondeos
Old Aug 17, 2006 | 05:02 PM
craig rs's Avatar
craig rs
wicked cheers ppl much appreciated
Old Aug 17, 2006 | 08:13 PM
HORNETS7's Avatar
HORNETS7
think ive got some knocking about if u get stuck m8!"
JoeyBoyden
Jan 4, 2024 02:36 PM
col93saphcos
Aug 7, 2015 03:21 PM
