Do halfords do cash refunds ?
Old Aug 15, 2006 | 10:07 PM
KSA-Cossie's Avatar
KSA-Cossie
Default Do halfords do cash refunds ?
I bought a road angel compact on sunday and can't get a signal in the cossie,works in every other car i've tried so want to get my £150 back .
Old Aug 15, 2006 | 10:13 PM
bigad4x4's Avatar
bigad4x4
Grey area that buddy, just explain the situation to them that it doesnt
work in the cossie and they should refund it to you if not
get £150 worth of magic trees
KSA-Cossie's Avatar
KSA-Cossie
fpmsl at magic trees
Old Aug 15, 2006 | 10:16 PM
Redkop's Avatar
Redkop
Check that your cigarette lighter socket is working properly first.
Old Aug 15, 2006 | 10:17 PM
AlexF's Avatar
AlexF
have you got a heated front screen?
if so thats the problem!
Alex
KSA-Cossie's Avatar
KSA-Cossie
Hi Lynne,the unit powers up but doesn't get a signal.
Old Aug 15, 2006 | 10:33 PM
Phil's Avatar
Phil
Jeebus
KSA-Cossie
Halfords are usually very good for refunds
Alternatively I think you can get an external aeriel for the road angel, so you can place it somewhere other than under the heated front screen.
Old Aug 15, 2006 | 10:35 PM
KSA-Cossie's Avatar
KSA-Cossie
Alex
I do m8.
Old Aug 15, 2006 | 10:36 PM
KSA-Cossie's Avatar
KSA-Cossie
Originally Posted by Phil
KSA-Cossie
Think i'll just take it back,cheers m8.
Old Aug 15, 2006 | 10:41 PM
Redkop's Avatar
Redkop
How long have you waited for a signal?
I've waited ages - as long as 30 mins sometimes. Wait for 10 mins if it doesn't get a signal, unplug it then plug it in again.
Road Angels are notorious for taking a long time to pick up a signal.
Another way to do it to see if the unit is faulty, is plug RA in and put it on the roof of your car so it can pick up a clear signal, you might still have to wait 15 mins or more - when and if it does, then put it back in your car.
Old Aug 15, 2006 | 10:43 PM
Cam's Avatar
Cam
Heated screen means you have to use the optional antenna to get a signal
Old Aug 15, 2006 | 10:46 PM
ECU Monitor Enthusiast
Had the same problem in my Escos, was the heated front screen.
Old Aug 15, 2006 | 10:47 PM
KSA-Cossie's Avatar
KSA-Cossie
What did you do simon did you keep it or not ?
Old Aug 15, 2006 | 10:48 PM
KSA-Cossie's Avatar
KSA-Cossie
Hd it in my van all day today and it worked fine,put it in the cossie and no signal after an hour of waiting.
Old Aug 15, 2006 | 10:49 PM
KSA-Cossie,
Gave it to my brother as a birthday present and sold the escos too
Old Aug 15, 2006 | 10:56 PM
Redkop's Avatar
Redkop
RA works fine in my cossie with a heated screen - I've had an RA Classic and now have an RA 2 along with a TomTom Go 700.
Old Aug 15, 2006 | 10:57 PM
Redkop's Avatar
Redkop
You might not have been getting a clear GPS signal in the cossie, try the roof method
Old Aug 16, 2006 | 06:33 AM
KSA-Cossie's Avatar
KSA-Cossie
Will try it today,thanks lynne.
Old Aug 16, 2006 | 06:38 AM
Chris Honeywell's Avatar
Chris Honeywell
I also never had a problem in my escort with a heated screen
Old Aug 16, 2006 | 06:46 AM
ProjectBobcat's Avatar
ProjectBobcat
Yes they do cash refunds as long as you have your reciept and paid in cash originally, if you dont have your reciept they will only exchange.
Old Aug 16, 2006 | 09:06 PM
James's Avatar
James
I have a RA Compact and it works fine with my Sierra heated front screen.
Old Aug 17, 2006 | 08:47 AM
Chris S's Avatar
Chris S
WITH SAT NAV ECT ITS EXEMPT FROM THE 28 DAY MONEY BACK GUARNTEE AT HALFORDS
tankybaby66
Feb 6, 2016 02:24 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
155lee
Sep 23, 2015 01:27 PM
hopper350
Sep 4, 2015 12:53 AM
