amal valves, been advised to fit a hi/low boost switch
had my new cossie to Well Lane turbos on saturday, just for basic tune up & R/R.
made 262bhp. they said it was spot on but the boost isn't holding, peaks at 16psi then holds 10psi, and slowly creaps back up to 12psi by the time you get to the rev limiter.
well lane said it was probably just the wiring from the ECu to the amal valve (being old) and the its not sending pulses as fast?
they told me to wire up a high loq boost switch to over come the problem?
does that sound right?
thanks lads
thanks lads
If the wiring or amal connector is old/faulty and causing intermittent (spelling?) problems you will notice it by the pretty violent cut outs.
For example if its boosting 16psi and the amal valve shuts off it will go back to the preload set boost instantly and that aint so pleasant. On my cossie it felt like a brick wall. Seems strange they says this because of the boost fading. If you swith the amal valve off it will drop rapidly.
i would think it would not make a difference as im sure the high low boost switch is just a wire going from earth to swich to pin 11 on the ecu if this is the case when it is swiched off for full boost there will be no difference....
unless he means an in car adjustable boot controller which will work off the pipe work and bypass the amelvalve......
thanks lads
andreas - thats what i thought it would be, but they said the actuator is fine, not sure what it is but it has a turbo technics sticker on it
the way Well Lane told me to wire up the hi/low boost switch was direct to the amal valve wiring
one wire going to earth, one wiring going to the green/brown wire on the amal valve (i thought this sounded really wierd)
hmmm, i have no faith in well lane.
Get a NEW -31 actuator, take it somewhere decent for a setup.
The actuator when its on the car, should be half a hole out on the arm for the wastegate iirc, this is the preload.
Ie when you offer the actuator up to the turbo and wastegate, you should be able to see half of the hole on the rod end it self, as the wastegate arm should be half visible.
man, thats a hard thing to describe this early in the morning.
Half a hole of pre-load on the acutator is correct. Jets in the amal valve are then used to bring the boost up. Best option is to junk the amal valve and get a decetn after market boost controller
and you own a cossie? god help you son
get a -31 actuator
Leave it in the box
Book in with a proper tuner
Get them to fit and setup
Drive away happy you havent busted something, but slightly skinter
get a -31 actuator
Leave it in the box
Originally Posted by SapphyMike
why rich?
Why not let the ECU control the boost, rather than some 3rd party item?
If Well Lane have told you your wiring is old and thats the problem, why have they told you to wire a high & low boost switch into the original wiring
If anything replace the 2 wires to the amal valve as far as you can cut them back & get a new actuator like Mike said.
Gotta love Well Lane
yeah think i will just buy a new actuator,
mike- spoke to NMS on saturday bout there "gunship" chip/setup, soon as i get some money im off down
think i just get them to take a look
thanks paul, i'll have a stab at the wiring,
would replacing the amal valve be a good idea?
well lane = set of cocks
I remember, a few years ago, was wathing a rolling road session, some lad with a cossie was having a "setup". Blokey on the RR was pissing about with the fuel pressure reg and then doing more power runs
It ended in tears with the engine going pop at full tilt while in 4th.
the RR operator (if you can call them that
) got out and said "shift it, its fucked"
I will never take a car to Well Lane - took a car there once, it had more power before they "tuned" it.
good lad cawood, well tbh, a new -31 is deffinately something you will require without a shadow of a doubt.
thanks, yeah to TBH i dont like well lane, since i just got the cossie i wanted a quick "check over"
yeah mike, told em u recommended me
i thought fook it see if NMS can fit me in now for the gunship (this was saturday morning)
so i rang well lane and cancelled with them (told em i ad my tyres slashed)
rang NMS up asked if i could pop down, was told it wasn't as simple as that as it needed live mapping, etc
so i had to ring well lane back again and uncancell my R/R with them
LOL!!
im surprise they even entertained you if you told them i recommended them
- actually they're doing some work for me at the moment, and will be doing more work for me too
When is your car booked in for? last time i spoke to Karl there was a massive waiting list LOL all the decent tuners have waiting lists
i have taken my motor to Well lane a few times with no problems at all! Just took it again on friday and its cool again!
they havnt ever upset me personally although i have heard some horror storys!
i've got a few horror stories but i cant be arsed going into them
just never ask them to fit a GRS for you
mike - told him i'd ring him back this week to arrange a date as its not just a "drop your car in for an hour job"
they better not bump the price up now cos you recommended me!
yeah he mentioned a bit of a waiting list, 3 weeks about lol, not bad tho cos it give me time to save up
LOL, its gone gone down then
nah, price wont go up, but i doubt it will go down either
it will be a good job regardless, and i GUARANTEE you will smile as soon as you plant your foot to the floor
infact fuck it, im after a quick txt to karl, i think im gonna go gunship on my engine for the time being anyway til i can afford more power - unless someone has a cheap T34 to sell me
No one's mentioned the amal valve jetting, which when done properly allows peak / held boost to what the tuner wants (dependant on turbo - e.g. some just cannot hold certain boost higher up the rev' range depending on engine spec' etc.)
As said above, wiring up a high/low switch won't cure this problem.
Red_bull
Aug 9, 2015 08:34 AM
