Urgent help - air con compressor and shims ?
Old Aug 14, 2006 | 05:19 PM
Petrucci's Avatar
Petrucci
Default Urgent help - air con compressor and shims ?
Hello all
following on from my air con problem (the magnetic clutch of the compressor has disappeared alone, must have fallen ), i managed, thanks to a miracle, to find the good part at Ford. The problem is, i have the magnetic clutch that goes before the pulley, but don't know how it is attached... and it also comes with shims of various widths (from 0.8 to 1.4 mm) and i don't know which one to use... can anyone help me, and post pics of the disassembled parts and of the compressor so i can fix all this tomorrow?
cheers
Old Aug 14, 2006 | 06:38 PM
Petrucci's Avatar
Petrucci
Old Aug 14, 2006 | 08:31 PM
foreigneRS's Avatar
foreigneRS
Testing the future
pay for my flight and i'll come over tomorrow and do it for you. could do with a few days in the sun
give me a while and i'll see what i can come up with (if my pc doesn't crash again )
Old Aug 14, 2006 | 08:36 PM
Petrucci's Avatar
Petrucci
would be outstanding pal
Old Aug 14, 2006 | 08:45 PM
foreigneRS's Avatar
foreigneRS
Testing the future
does something like this help?
taken from my company's american website http://www.sanden.com/support/servic..._contents.html
your compressor is manufactured by Visteon, that used to be part of Ford, and is probably an FS10 type compressor. try a search around for a service manual on that. it's important to get the gap correct between the clutch parts with the shims
if by the morning you still don't have what you need, i can ask someone within Ford for you
Old Aug 14, 2006 | 08:48 PM
Petrucci's Avatar
Petrucci
that's a great help already mate, many thanks !
any idea about the shim width i have to use ?they range from 0.5 to 1.4 mm, i just checked...
Old Aug 14, 2006 | 08:50 PM
Petrucci's Avatar
Petrucci
erm... i don't have 21b nor 21a on my car it seems
Old Aug 14, 2006 | 09:44 PM
foreigneRS's Avatar
foreigneRS
Testing the future
you won't have, or 26a and 26b, they're heavy duty options for tractors and stuff.
there's no way i can tell you what shims to use, as you need to assemble the components together until you have the right gap between the 2 friction surfaces (about 0.5mm)
Old Aug 14, 2006 | 09:47 PM
Petrucci's Avatar
Petrucci
ok, so the final gap must be 0.5 mm with everything in place ?
that's cool, wasn't aware at all of what distance was needed in the end
Old Aug 14, 2006 | 09:56 PM
foreigneRS's Avatar
foreigneRS
Testing the future
about that, maybe slightly different for the visteon compressors but that will be ok.
Old Aug 15, 2006 | 03:17 PM
Petrucci's Avatar
Petrucci
ok, gap now set to 0.5mm thanks to the 0.7mm shim !
now, i tried to start the compressor, but was wondering, is it normal for it not to start because it's empty ? (no "tickle" noise when turning air con on, but of course no gaz yet in the circuit...) Maybe it's a security ?
thanks
Old Aug 15, 2006 | 04:01 PM
foreigneRS's Avatar
foreigneRS
Testing the future
exactly. there is a pressure switch with 3 settings:
1) for low pressure that does not allow the compressor to come on if it is not reached
2) for medium pressure to put the fans onto maximum speed
3) for high pressure to cut off the compressor again for safety
if you want to test it, just feed 12v directly to the clutch (not while the engine is running, or you will damage the compressor internally)
Old Aug 15, 2006 | 04:03 PM
Petrucci's Avatar
Petrucci
amazing mate, a HUGE thanks for your help, it's been very precious to me !!!
Old Aug 16, 2006 | 07:54 AM
foreigneRS's Avatar
foreigneRS
Testing the future
no problem fella. if i can't provide decent advice on that after doing it for over 10 years, then i'm not much use to anybody
Old Aug 16, 2006 | 08:14 AM
Stu @ M Developments's Avatar
PassionFords Creator
Brilliant advice Nick.. top work.
Talking of Advice.. see page 20 of this months Fast Ford
(September issue)
Old Aug 16, 2006 | 12:57 PM
foreigneRS's Avatar
foreigneRS
Testing the future
will do at the weekend mate
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
