Rev counter not working.....why?
Aug 9, 2006 | 05:52 PM
My Rev counter has stopped working since i fitted a new metering head.......
I know the metering unit is nothing to do with it, but i may have disturbed a wire or something....But where abouts would it be???
Aug 9, 2006 | 06:08 PM
There's a green wire running from the coil to the clocks (I think).
Aug 9, 2006 | 07:07 PM
the rev counter may just be broke mine just stoped working so i got a cheap one of ebay,works fine now
Aug 9, 2006 | 07:21 PM
It was working fine till i change the metering unit...i think i have just knocked a wire
I HOPE
Aug 9, 2006 | 07:42 PM
as said. green wire from coil to clocks. It goes through a supressor near the coil, so check that connection too. Also, give the clocks a punch
Aug 9, 2006 | 07:57 PM
Aug 9, 2006 | 10:21 PM
yeah the green wires go into a suppresor which do affect the clocks think they are a green and red on the pssenger side inner wing near the coil!
Aug 10, 2006 | 10:31 PM
this thing went on me and man at my local motor factors told me it was a ballast resistor. i can only say what i was told an dont want to give you the wrong info!
Aug 11, 2006 | 11:21 AM
maybe a ballast resistor to reduce coil ringing for a more stable reading. Would have to inspect it properly to confirm
Aug 15, 2006 | 07:12 PM
have u got this sorted
Aug 15, 2006 | 10:23 PM
Not yet....havent got the car back yet
Sep 2, 2006 | 11:21 AM
Still not sorted and it is fucking annoying me now
Sep 2, 2006 | 11:37 AM
Quote:
punching the clocks
Tsk Tsk, i find a more tactful wallop on the top of the dash is better
Tiff, what have you tried so far?
Sep 2, 2006 | 06:12 PM
I have tried disconnecting the thing near the coil and cleaning it up.
Traced the wiring to make sure it is not cut/split
Applied force to the clocks
Sep 3, 2006 | 11:44 AM
Have you continuity tested the green wire from the coil end to the plug on the back of the clocks?
And is there a suppressor inline in the green wire?
Sep 3, 2006 | 11:49 AM
Its fucked
Sep 3, 2006 | 12:16 PM
give the dash above a goodthump.. worked on my xr3i
load's!!!!
Sep 3, 2006 | 01:05 PM
Quote:
Originally Posted by Pennywise
Its fucked
There we have it boys
Sep 3, 2006 | 01:41 PM
check the condition of the 12v switched and earth supplies
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
