who's running an oil cooler?
Old Aug 9, 2006 | 09:47 AM
Hrsturbo's Avatar
Hrsturbo
Default who's running an oil cooler?
did you fit an oil thermostat to bypass the cooler when cold??
is this a worth while install or one which is not nomally needed??
best place to install? behind the bumper there is a nice bit of space on the drivers side?
any thoughts much apreciated
thanks
Old Aug 9, 2006 | 09:57 AM
vroomtshh's Avatar
vroomtshh
Definitely fit a thermostat. Over cooled oil is just as bad for your engine as overheating oil.
Old Aug 9, 2006 | 08:24 PM
Brookesy's Avatar
Brookesy
You got 2 choices you can fit a thermostat in the oil hose or you could fit a thermoblock instead of a sandwich plate
3drRich
Sep 13, 2015 07:32 PM
mint_s2
Sep 2, 2015 08:58 AM
Sheepdisease
Aug 30, 2015 09:11 PM
YODI
Aug 30, 2015 01:12 PM
Adam-M
Aug 26, 2015 05:53 PM
