Very sick RS Van!
Old Aug 8, 2006 | 05:43 PM
djsri's Avatar
djsri
Default Very sick RS Van!
Anyone wanna see my print out today
not looking good at all,knew i had problems but christ! all standard but has cosworth actutator,dump valve,just seems to loose power when you put ya foot down,any idea's
[/img]
Old Aug 8, 2006 | 10:47 PM
RST Ski's Avatar
RST Ski
Is that a massive flat spot?
Old Aug 9, 2006 | 09:12 AM
djsri's Avatar
djsri
Big time m8!
Just changed the dizzy last night whole new setup plus cap seems a lot better now but everytime i stop the van she just boils over!
Had new water pump
New thermostat
any ideas on that one?
Old Aug 9, 2006 | 10:28 AM
RST Ski's Avatar
RST Ski
is the flat spot in every gear and does it happen everytime?
Old Aug 9, 2006 | 01:23 PM
djsri's Avatar
djsri
It did do m8 until i change the dizzy over
any ideas why it boils over when the engine is switched off?
changed water pump plus thermostat.
Old Aug 9, 2006 | 01:53 PM
RST Ski's Avatar
RST Ski
most rs enigines do that cos the turbo acts like a kettle even tho everything is off
does it actaully piss out, or can u just hear the water boiling in the bottle?
Old Aug 9, 2006 | 02:08 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
leave it running till it cools down, the fan will prob come on so wait till it goes off, pain in the ass check condition of rad also/header tank cap too
Old Aug 9, 2006 | 03:54 PM
djsri's Avatar
djsri
hi guys
thanks for the reply
Just noticed that it only happens when you switch the engine off,running seems fine (normal temp on gauge) when off it floods out?
Old Aug 9, 2006 | 04:01 PM
RST Ski's Avatar
RST Ski
as above its worth checking your coolant bottle cap to see if its holding pressure, im sure boiling up afterwards is normal as ive seen something on that posted before but yours may look worse as the cap isnt holding pressure and it leaking out, i asume your fan cuts in fine ect ?
Old Aug 9, 2006 | 04:11 PM
djsri's Avatar
djsri
yeah fans cuts in m8
i'll try the cap first,bottom end does sound like its starting to knock,would this have any affect on the cooling side?
Old Aug 9, 2006 | 04:15 PM
RST Ski's Avatar
RST Ski
the other way round would, if ur cooling system is not working properly that could cause problems for the engine ie knocking
Old Aug 9, 2006 | 04:57 PM
RST Ski's Avatar
RST Ski
didnt they tuner say anything when he rolling roaded it? normally they comment on something along the lines of what it could be?
Old Aug 9, 2006 | 05:31 PM
djsri's Avatar
djsri
didn't have a clue m8,said it was such an intermittent fault didn't know what it was lol, cost me £50 for him to say that! got it home done dizzy running much better just boiling over prob now!
Old Aug 9, 2006 | 05:44 PM
RST Ski's Avatar
RST Ski
any signs of oil in the coolant or other way round?
Old Aug 9, 2006 | 05:56 PM
djsri's Avatar
djsri
nope nothing m8, thats whats so strange about it,flushed rad etc still doing it.
gonna get a new cap tomorrow see if that helps
Old Aug 9, 2006 | 06:08 PM
RST Ski's Avatar
RST Ski
let us know how u get on when u get it
Old Aug 9, 2006 | 07:00 PM
JamboRS's Avatar
JamboRS
focus rs 1672
was the rollin road done in 5th gear?
Old Aug 9, 2006 | 07:19 PM
djsri's Avatar
djsri
RST Ski will do bud,fingers crossed hey! new block me is thinking...
yeah he did do 5th gear run,why that JamboRST you thinking something?
Old Aug 9, 2006 | 08:15 PM
shane's Avatar
shane
Sounds like ur caps faulty mate,i had the same problem with my S2! The seal split in the cap,change the cap and its been fine ever since!
Until i ripped the car to bits!
Neil Clark
21
Oct 1, 2015 07:02 PM
AJC
Oct 1, 2015 06:47 PM
Flatlinedan
Sep 18, 2015 12:41 PM
S3an
13
Sep 13, 2015 10:01 AM
