Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
MT75 4WD PART
Old Aug 6, 2006 | 10:03 PM
markk's Avatar
markk
Default MT75 4WD PART
i need the small oil tube that fits inside the tranfer case with the samll black plastic splash cover on asap
Old Aug 6, 2006 | 10:10 PM
xr4x4rs's Avatar
xr4x4rs
have you got a pick mate
got a mt75 v6 sat here which im just keeping for spares for th egears when i destroy my cosy box
got cosy boxes lying around so will have what u need if you can get a pic for me
Old Aug 6, 2006 | 10:13 PM
markk's Avatar
markk
hmm no pic tonight, when you remove the tranfer case, there is a long steel tube that just drains oil to the back of the tranfer, has a small swage line in the rear simple as that really
cheers
Old Aug 6, 2006 | 10:17 PM
xr4x4rs's Avatar
xr4x4rs
ok ill take a look tomorrow
i need to remove the rear prop holder or whatever its called lol to get treansfer box off
is this a special socket?
Old Aug 6, 2006 | 10:25 PM
markk's Avatar
markk
no if you just remove all the bolts from the upper tail section of the transfer then lever the case off the tube should be there pal
cheers
Old Aug 6, 2006 | 10:27 PM
xr4x4rs's Avatar
xr4x4rs
no worries mate
will take a look tomorrow for u
Old Aug 7, 2006 | 04:45 PM
xr4x4rs's Avatar
xr4x4rs
ok got the tube i think
whats this plastic guard ypur on about doe this sit ontop of the transfer housing?
is this the tube u need
Old Aug 7, 2006 | 04:49 PM
xr4x4rs's Avatar
xr4x4rs
sorry just had another look is this what you want same pipe but with a plastic shield on and a rubber grommet
if so pm your name and address ill get it in the post tomorrow for u
Old Aug 7, 2006 | 06:12 PM
markk's Avatar
markk
thats it pal
pm sent
mjonathan24
Oct 29, 2015 10:39 PM
Oct 1, 2015 02:00 PM
Iain Mac
Sep 30, 2015 09:39 PM
fordrallycar
Sep 30, 2015 07:57 PM
