frst running problems
Old Aug 5, 2006 | 09:20 PM
Pop S1's Avatar
Pop S1
Default frst running problems
help
frst when under load between 2500-3000 rpm it shuts down a cylinder and missfires had it on code reader it came up fault code 37 map cicuit fault have fit a new map sensor and checked wiring but all ok
have checked through rest of wiring and sensors and all seem ok has anyone any ideas before we try to source a ecu
ps was chipped but have unplugged it and let it remap itself but still same
many thanks pop
Old Aug 6, 2006 | 10:44 AM
Scottish Greg's Avatar
Scottish Greg
HT leads ?
Old Aug 7, 2006 | 01:15 AM
reisskahn's Avatar
reisskahn
Hi mate what spec and boost is the car??
Why was the chip removed???
Sounds like the overboost protection is kicking in with the chip removed
Old Aug 7, 2006 | 02:38 PM
Pop S1's Avatar
Pop S1
its got new plug leads on to eliminate this
its running 6psi because engines running in at the moment from fresh rebuild(was smoking before build but no missfire)
we removed chip to eliminate a map fault
its basically standard now chips removed
bigryrs
Sep 5, 2015 02:57 PM
bigryrs
Aug 28, 2015 05:32 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
