VERY daft question
Don't ask - I don't know
Only other way is to drill through the turret and bolt through from the underside I would think.......I'd use the allenkey type bolts. Not sure what clearance would be like with the strut though................
drill through the turrets and use 6mm allen head bolts with nylock nuts. you have to drop the struts down to do this and the clearence is very tight. when i did mine i got a selection of different length bolts and then cut them to size.
Those things are called rivet nuts i believe.......and i see where you are coming from not wanting to use self tappers
They look shit and go rusty etc. Make sure you use stainless will look so much better
As above...I used a M6 nut/bolt and cut down until only 1 thread was sticking through one nipped up. You have to drop the strut to do it though but it gives you a chance to coat everything with Waxoil once assembled
Originally Posted by NUTS RuS
Originally Posted by addiction
self tappers
o my god, what is the world coming too
Originally Posted by James Raby
Try and find a match for my paintwork, and I'll do it lol
some of the stuff on here is giving me sleeples nights
self tapers. wtf. why dont you tell him to glue it on you f*c$i!g nutball. drop struts offer up brace, drill through exact holes, use 13mm bolts, nylock nuts,cut down bolts so bolt is just through nut and refit struts. and as for the brace being aloy...... its to limit the flex betwen the strut tops not to keep legs straight if you wrap rest of car round an inconveinient obstical such as a tree.... or a bus shelter.
but i dont drive like an idot and im not suggesting anyone else does, meh , im happy with my self tappers and alloy strut brace ,and im quite happy in my ignorance, best tip here is , dont get stressed its not on your car
