this is getting annoying now, once the cars hot and i pull up to a set of lights i get a smoke cloud out the back. pull off and its fine, on boost its fine. also does it sometimes when lifting off throttle.
pulled the boost hoses off the turbo earlier and there was no oil in them when is making me wonder if it is turbo or maybe something else.
naa its not smoking on start up. thats why i didnt automatically think stem seals. its a tricky one.
i put another post up about a cheap turbo i'd found. reckon its any good?
in the early stages of the stem seals going then you could get smoke just on overrun, once they are properly gone then it will defo be on start up. Try the stem seals first before spending major bucks, its worth a try chap.
when my stem seals went it was only on start up didnt get any smoke on overrun
thing is with my breather system its a bit strange, it had a little filter on the breather by the fuse and relay box but it got lost somewhere whilst driving. now its just lying open
is making a bit of a mess, what can i do to it and coudl this be causing it?
