torque
what is it, or what are the factors that determine whether your car makes good torque over actual bhp? ie you can have 2 more or less identical chipped cars,using same chips,injectors etc,but one of them will produce far more torque than the other,why is this?
think it is detemined by what components are used,eg turbo,pistons etc.but not sure how you go about finding out whats got to matched to to high torque.maybe compression ratio to?
PS
No you cant, unless there is a fault they will be the same torque and the same power if t hey are the same spec.
Torque is the force and power is the rate at which you can apply the force.. in an ideal world, "identical" specs will provide idential results.. however rolling roads are bullshit, engines are rarely the same spec (owners rarely know what the actual spec, history is).. it's all academic really!
PassionFords Creator
If turbos, you will normally find one has more boost PEAK than the other.
Camshaft TIMING of course also plays a part in the peak torque area.
Originally Posted by NIL 7717
Originally Posted by J871yhk
Originally Posted by Porkie
Boooooooooooooooost!
J871yhk
is that your mini in sig?whats in it?
170 bhp A-series turbo
www.afracing.com/mini.htm
DavidK
Sep 27, 2015 02:55 PM
