Baily D/V Repairable??
Old Aug 1, 2006 | 05:28 PM
righthooker's Avatar
righthooker
Default Baily D/V Repairable??
My Dump valve has started to stick open Which is a pain in the arse as you can imagine
Now ,it is the new type ,with the allen key bolts .
So, is it a spring or what ,that is foooked ,and if so is it easily done and bought???
Old Aug 1, 2006 | 06:34 PM
fordsportjay's Avatar
fordsportjay
piston type-just clean out the bore and it should be ok,the bore gets dirty and stops the piston from moving freely.
hope this helps
Old Aug 1, 2006 | 06:40 PM
righthooker
is it easy to take apart mate or will it spring open or what??
Cheers for the reply
Rab's Avatar
Rab
Fucking superstar........
Put it in the bin
Hope this helps
Old Aug 1, 2006 | 06:44 PM
righthooker
NO i like the gay sound it makes
Old Aug 1, 2006 | 07:11 PM
Rab's Avatar
Rab
Suits you sir
Buy a tin of Carb cleaner
Old Aug 1, 2006 | 09:24 PM
The Youth.'s Avatar
The Youth.
tommorow, we will see a post entitled.......
can you buy dump valve springs as mine has flew accross the garage floor somewhere!!!!
steve
Old Aug 1, 2006 | 10:02 PM
righthooker
stay tuned for the next episode
Steve ,i have a spare D/V may be safer to swap em
Old Aug 1, 2006 | 10:03 PM
CharlieSaff's Avatar
CharlieSaff
Steve
Fudgey's Avatar
Fudgey
Baby Cheesus
you sure the diaphram hasnt split?
thats quite common and will of course lead to it sound like its leaking.
the springs aint that hard in the m either so will be ok to open, just cover it so it dont blast accross the room
Old Aug 2, 2006 | 12:13 AM
zippyobrien's Avatar
zippyobrien
piece of piss to open , there is no diagraph
just realiease the top slowly
Old Aug 2, 2006 | 12:26 AM
Dean Saff's Avatar
Dean Saff
you should do what I did with mine,
Take it to a Driving range and see how far you can Smack it....
FOURRRRRR..........
Old Aug 2, 2006 | 08:37 AM
GT2's Avatar
GT2
Send it to Bailey as they refurbish free of charge
Old Aug 2, 2006 | 09:15 AM
turbo.jon's Avatar
turbo.jon
i had twin piston 1 ages ago and the second little spring had snapped got in touch with bailey who wanted ove Ł50 for this little spring so chucked the bloody thing in the bin
Old Aug 2, 2006 | 09:55 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Considering you work for a Ford magazine, I would have thought it your duty to know that the Bailey dump valves are of the piston variety and don't have a diaphram .
Anyway, RH, if you run the dumpvalve on the hot side of the intercooler, it could be sticking due to the piston expanding with the heat it is seeing (especially if the dump valve is a few years old), as it is a known problem on the early ones that went to hot climates where ACTs were high. The material of the piston has recently been upgraded to prevent this .
Old Aug 2, 2006 | 12:22 PM
righthooker
on the cold side Mike ,will have it opend and clean it this afternoon .
See if that helps
tankybaby66
Feb 6, 2016 02:24 PM
gambo08
Feb 4, 2016 10:49 PM
rsguy
44
Sep 29, 2015 03:29 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
