Another electrical problem
Old Jul 31, 2006 | 04:32 PM
s2rstony's Avatar
s2rstony
Default Another electrical problem
Recently my stereo has been cutting out if I turn it up too much,
I put this down to a poor earth, so the pulled the dash foward
and I was right, the earth was practically hanging off,
now since putting it all back together my stereo
and clock loose its memory when the ignition is turned
off and the green relay above the pedals starts tapping
while im driving. I dont know what the relay is for,
I think it may be the heated screen? Also my handbrake light
has a mind of its own.
anyone got any ideas as to what might be causing this to happen?
cheers Tony
Old Jul 31, 2006 | 04:54 PM
RST Ski's Avatar
RST Ski
sounds like you've disturbed the perminant live feed when u fixed your earth as your clocks loosing its memory
Old Jul 31, 2006 | 05:29 PM
s2rstony's Avatar
s2rstony
what is that wire connected to?
Old Aug 1, 2006 | 08:35 AM
sime73's Avatar
sime73
if its high channel output then its usually a fused feed straight from the battery
Old Aug 1, 2006 | 08:27 PM
s2rstony's Avatar
s2rstony
thanks fellas ill take a look
Old Aug 1, 2006 | 09:35 PM
SafeChav's Avatar
SafeChav
The green relay is the ABS relay.
Do you have your stereo wired up to turn off with the ignition?
Old Aug 2, 2006 | 12:50 AM
Combi_Chris's Avatar
Combi_Chris
just fuse it from the battery ,and use a new clean earth you will have a perm live [ battery ] and an ignition live or acc live, you should be able to find it using a m/ meter , the handbrake light ,like mine , has a mind of its own you say ?
try checking right next to the h/brake under the carpet there is a sensor thingy blob, maybe thats loose. mine is, but im not bothered , at the mo, lol
hth
Old Aug 2, 2006 | 08:14 AM
SafeChav's Avatar
SafeChav
Both of you, check your brake fluid level................
Old Aug 2, 2006 | 11:13 AM
Combi_Chris
i did already , its over the max line , its the handbrake sensor switch in mine, it only does it when using the handbrake and NOT while driving, i wasnt very clear before.
Old Aug 2, 2006 | 04:32 PM
s2rstony's Avatar
s2rstony
quality advice, checked my fluid, its fine no probs with the braking at all!
ill try running a new fused live wire through to see if that helps my stereo, its wired in at the mo so it can be turned on without the ignition being on. thats how it worked before anyway lol.
doesnt help my clock much though
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Kam B
Sep 24, 2015 10:40 AM
focus2351
Sep 9, 2015 09:33 PM
