running problems and some fault codes
hi peeps new to the site, bought my car the other day. its an xr3i efi converted to turbo with a full fiesta turbo engine and ofac loom. running a T3.
basically its running really rough at idle and not pulling properly. also intermittantly when cruising at motorway speeds and floor it the car shakes and goes nowhere.
put a snap on scanner on it and had two fault codes. 47 - map sensor or cicuit fault and 59 - co potentiometer out of limits
does this mean it deffo needs a map sensor and potentiometer?
cheers chris
cheers chris
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
