t3/4 turbo
Old Jul 28, 2006 | 12:35 PM
turboben's Avatar
turboben
Default t3/4 turbo
hi peeps i have been offered a very cheap t3/4 t04e stage 3 turbo but i am only running a 1600 engine is this turbo going to work on my car or is it a waste of money also when would it kick in and how much difference would it make
sorry for all the questions just dont want to waste my money on something that will just sit on the garage floor.
Old Jul 28, 2006 | 04:00 PM
Liams's Avatar
Liams
I have one of these and ive been told it may be too big for my 16v'er! Wheres it from out of interest?
Old Jul 28, 2006 | 05:24 PM
turboben's Avatar
turboben
from a friend in romford
not a lot of good then
Old Jul 28, 2006 | 05:40 PM
adamS2RST's Avatar
adamS2RST
What's the 1.6 had done to it?
Old Jul 28, 2006 | 06:00 PM
turboben's Avatar
turboben
it is a standard bottom end the head has a kent cam and vernier pulley it has a pts chipped ecu fifth injector magnex zorst k&n induction kit and a front mount grs running 15psi
Old Jul 28, 2006 | 06:16 PM
Noisy Boy's Avatar
Noisy Boy
You will need i abit of work on the bottom end to get good use out of the turbo i think mate
Old Jul 28, 2006 | 07:29 PM
turboben's Avatar
turboben
someone told me i will only get full benefit on an engine capacity over1.9 is this true or will it be ok on a 1.6
Old Jul 28, 2006 | 08:01 PM
nigel b's Avatar
nigel b
i used to run one with no problem on the 1.6
Old Jul 28, 2006 | 08:54 PM
turboben's Avatar
turboben
when did it kick in and how much better is it than a t3
Old Jul 28, 2006 | 10:07 PM
nigel b's Avatar
nigel b
depends on what has been done and what boost your gonna run
it was on boost by about 3000rpm
Old Jul 29, 2006 | 07:47 PM
zippyobrien's Avatar
zippyobrien
im runing one on my rs,
got a full stage thrre head, piper cam, enlarged ports and valves, and port matched inlet manifold (plus obviouse fulling and a few tweaks to bottom end
im currently running around 25 psi att he mo,
there isnt much power below 3 (theres none)
sarts making boost at 3 and comes in really fast from there
not advisable for a everyday car!
Old Jul 29, 2006 | 08:08 PM
©hatter Box's Avatar
©hatter Box
t34 will be miles to big for an 1600 unless ur all still bottom end with big boost the right turbo for un 1600 is t3 hybrid with .48 with 55 trim
Old Jul 29, 2006 | 08:41 PM
turboben's Avatar
turboben
its not a t34 it a t3/4 its actually called a to4e
Old Jul 30, 2006 | 10:16 AM
©hatter Box
whats the size of the exzorst housing and trim?
Old Jul 30, 2006 | 10:22 AM
turboben's Avatar
turboben
3" INLET
2" OUTLET
spec is as follows
WET FLOATING BEARINGS
1/8 NPT OIL INLET
T3 / T4 FLANGE
FITS T3 AND T3/T4 MANIFOLDS
.50 A/R COMPRESSOR
.63 A/R TURBINE
.57 TRIM
Old Jul 30, 2006 | 10:54 AM
JamboRS's Avatar
JamboRS
focus rs 1672
stage 3 t3 is adequate to around 260bhp on an rst,anything else is overkill and not needed unless power figures are more important than driveability
Old Jul 30, 2006 | 11:42 AM
turboben's Avatar
turboben
why will it affect the drivabillity of the car
Old Jul 30, 2006 | 02:38 PM
JamboRS's Avatar
JamboRS
focus rs 1672
bigger turbo on a 1600 is not gonna make boost till over 3 k,my stg 3 t3 makes full boost by then
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
