Just fitted the zvh. few questions.....
Hello. just fitted a 2.1 zvh to my 3i replica (now converted obviously). Just wanted to ask a couple of questions really.
*can i use my 3i starter motor and alternator?
*On the back of the inlet manifold there are four square connector blocks. How do i work out what plug is what?
Thanks in advanve peeps
your alternator will fit but you have check witch cvh bracket you use as there's 2 differant kinds, your cvh starter will fit if your using a bc (cvh) gearbox, i could be corrected but thats how i did mine
marky_g
Aug 15, 2015 10:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
