4x4 too rwd on a cossie
cheers for the info, afriend of a friend has a 4x4 and really wants a rear hooker again but his 4x4 is good nic and wants to properly convert it, so i guess 2wd sump and hubs and t5 box is the best way too go?
Originally Posted by big_wig_074
1.sell 4x4
2.buy 2wd
3. spend extra cash on the piss!
2.buy 2wd
buttt.......
the car is in very good condition and has had quite a bit spent onit, would lose alot of money selling it and its hard work finding the right cossie too
driveshafts
diff
rear beam
prop
gearbox
sump (though not sure if its a necessity to change it)
exhaust (although it may still fit)
thats about all the bits you need from the 2wd
you will also need to find a suitable gearbox crossmember from somewhere iirc
diff
rear beam
prop
gearbox
1.sell 4x4
2.buy 2wd
2.buy 2wd
buttt.......
Originally Posted by loader5710
So it is different in the rear then.
not necessary. a std t5 cross member and a length of 50mm box section is all that's needed to fit a t5 into a 4x4 shell, done it twice.
although, i never attempted it myself. hot a mate who's doing a escos RWD, he managed to find a crossmember off a sierra that would do the job
You will need to change
Front x member
front hubs
front struts
steering rack
sump
oil pickup pipe
oil pump
gearbox
gearbox mounts
prop
and as said rear diff etc , but you can use the 4x4 if you want
Paul
Front x member
front hubs
front struts
steering rack
sump
oil pickup pipe
oil pump
gearbox
gearbox mounts
prop
Paul
I never changed the oil pump or pickup when putting a 2wd sump onto my engine
Only thing that needed adjusting was the piston spraybar feed for cylynders 1 and 2, then bend the nozzles into the correct place again. The sump then went on with no fuss
You cant put a 2wd oil pickup pipe onto a 4x4 oil pump
And bending the 4x4 pickup pipe isnt a good idea , i have seen many blown bottom ends after doing this
Gracy , I hope you have done it correctly or going round corners fast may lead to a rattle or 2
Paul - I didn't touch the oil strainer pick up pipe, just the piston spray bar pipe for cylynders 1 and 2, then aligned them correctly as to what they previously were.
we are only talking 2 or 3mm movement of the spraybar aswell, nothing critically major
turbotrev
39
Apr 17, 2016 09:03 PM
Russ Payne
Sep 25, 2015 08:29 PM
