S1 wont start
Old Jul 15, 2006 | 03:03 PM
kurdt5's Avatar
kurdt5
Default S1 wont start
fitted my fuel pump and then primed it for a while.
started the car but all it does is turn over go to start then just carry on turning over.
i released a fuel inj pipe icase of air, but the car still does the same.
do i need to get a tow and bump the car??
its not been started for 2 weeks whilst i sorted the pump.
cheers peeps
Old Jul 15, 2006 | 05:49 PM
TURBO BOI's Avatar
TURBO BOI
u got live feed down to the pump?
Old Jul 15, 2006 | 07:43 PM
kurdt5's Avatar
kurdt5
yeah, everything seems to be working, just turns over goes to fire then just carries on turning over.
is it worth bumping the car?? cant see why she wont start.
Old Jul 15, 2006 | 07:51 PM
TURBO BOI's Avatar
TURBO BOI
if ya got spark (and correct firing order) fuel and compression then yeah a tow start could be worth ago
Old Jul 16, 2006 | 01:05 PM
SafeChav's Avatar
SafeChav
You shouldn't really need to bump it unless the battery is weak.
Something is still a miss if it won't start
Old Jul 16, 2006 | 01:58 PM
kurdt5's Avatar
kurdt5
Found the problem.
the small outlet pipe is leaking, the new banjoo is quite big and looks to have caused a split.
will have to order a new pipe.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
