B&M Quickshift fitted
Old Jul 15, 2006 | 09:19 AM
Oranoco's Avatar
Oranoco
Default B&M Quickshift fitted
OMFG! How little movement in th elinkage now. I can change gear witha deft flick of my wrist.
Not that it'll do me much good though seeing as the turbo is in bits on the workshop bench
CheeRS to Rob & Co at SCC.
Old Jul 15, 2006 | 10:41 AM
Patto's Avatar
Patto
been thinking about one of these myself, i take it from your its not like stirring a bowl of porridge anymore, lol....
How much are the b&m kits i presume there that hard to fit.? more fiddly than anything..?
Old Jul 15, 2006 | 02:10 PM
gambit's Avatar
gambit
Default quickshift
they are actually very very easy to fit to a series 2 and you can get them from woodford garage mate. check the installation instructions on b&m site and then see if you are confident.
Old Jul 15, 2006 | 08:59 PM
BillyCabrio's Avatar
BillyCabrio
Oranoco
Is yours nice and smooth? Mines a very nothy change
Sometimes can't find the gear without giving it that extra ooomph in
Old Jul 15, 2006 | 09:04 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
You guys need to lose your woman hands with a B&M. Paul, remember it's an Escort you are driving, not a BMW.
One of the best mods I have ever done though. Didn't think it was possible to shorten the ERST shift by that much!!!
I do them for Ł185 posted, by the way!!!
Old Jul 16, 2006 | 07:27 AM
gambit's Avatar
gambit
Default quickshift
one of the best mods i ever done too, highly recommended
Old Jul 16, 2006 | 09:39 AM
zippyobrien's Avatar
zippyobrien
the best mod ive done (cheers to christian)
but mine is very stiff and you do really have to slam it into gear, and my panssy uncle still cant get third gear with it hahaha,
makes the driving experienceso much better
Old Jul 17, 2006 | 07:24 PM
BillyCabrio
Christian and Beccy
Oi ya cheeky geeeeeeeeeeeet
I have a feeling that its not aligned properly thats all, 2nd to 3rd and 3rd to 4th are right bastids.
And sometimes it won't come out of reverse
Old Jul 18, 2006 | 07:36 AM
DanS's Avatar
DanS
I only have a slight problem getting mine into first but all the other gears are spot on. Like others say, every RST should have this mod
Old Jul 18, 2006 | 05:08 PM
GraphiteGray's Avatar
GraphiteGray
If you have to force it into gear wont it be damageing you gears?
Thinking about getting one for mine dont want to wreck my rebuilt box though
Old Jul 18, 2006 | 09:16 PM
Christian and Beccy
#1 in Spelling Club
No, 'force' is the wrong word. The parts have less compliance, hence the improvement in shift 'feel', but it requires you to be a little more 'purposeful' with your action!!
Won't damage your gearbox.
Old Jul 18, 2006 | 09:36 PM
DanRSturbo's Avatar
DanRSturbo
Christian, I may well be having one of these off your good self soon
Is it easy to fit ?
Old Jul 18, 2006 | 09:37 PM
dave_y's Avatar
dave_y
i fitted my B&M quickshift yesterday (thanks Christian ) now all i need is a gearbox to go with it!
Old Jul 19, 2006 | 11:41 AM
Christian and Beccy
#1 in Spelling Club
Is it easy to fit ?
Dan, they aren't bad to do. Worth spending a little time making it all nice and getting it set up right. I actually bonded all the parts of my centre console together from underneath to take away the vibration too. It's still as awesome as the day I fitted it and that was over 3 years ago!!
Dave y - Glad you got yours in!! Hope you get your 'box sorted soon!!
Old Jul 28, 2006 | 11:46 AM
Combi_Chris's Avatar
Combi_Chris
any chance of a piccy ,because i cant work out how low they actually sit in the center plastic trim....
Old Jul 28, 2006 | 04:52 PM
Oranoco's Avatar
Oranoco
I've still not driven the car since it was fitted
Picking her up in the morning and will do some.. err... testing on the way home
Old Jul 28, 2006 | 09:56 PM
zippyobrien
i do find it hard going into first (have to go from second, then to nuetrla, let of clutch then fist????
but is foookin sweet
Old Jul 28, 2006 | 10:06 PM
Combi_Chris
im getting some very mixed responses on theese b&m units, some say they work fine from the box, others have hassle , are they as good as people say ?
Old Jul 28, 2006 | 11:28 PM
gambit's Avatar
gambit
Default b&m
the shifters are awesome however it is true that you must be very direct with the gears inorder to have a smooth change. Trust me its well worth it, just fit it right (which is easy) and you will be very happy.
Old Jul 29, 2006 | 10:15 AM
Oranoco's Avatar
Oranoco
Just got back from my first drive with it..
Fuck me! It's simply awesome. Best money I've spent on the old girl for quite some time. No problems getting gears although snicking the gears stationary isn't nice on th eroad there are no problems at all. I would rate and recomend the unit highly and I'm just gutted it took me this long to get off my aRSe and get one
Old Jul 29, 2006 | 12:59 PM
NUTS RuS's Avatar
NUTS RuS
Glad your happy
Mine actually lasted 3 stages (in competition use) before shitting itself and fearing for the rest of its life.
A few mods to the bearing carrier selector which is now drilled and grub screwed instead of relying on the little rubber 'o' rings and we are sorted for life
Thats after B&M had to send me some new parts in its first week as the unit was faulty, but they came from the manufacturers within 4 days
As above - get them from Christian at APT
Old Aug 4, 2006 | 08:57 PM
dave_y's Avatar
dave_y
just drove my car up the road since i now have a gearbox
the gears are so precise and notchy compared to the standard setup its completely transformed.
i hear what your saying about changing in neutral you do have to be a bit more brutal with it lol.
the first couple of times i had to select 1st gear twice just to make sure it was in cause its so little travel.
I do get a bit of vibration through the lower bit of the centre console but i dont care
thans again christian!
Old Aug 9, 2006 | 05:08 PM
ivorbiggun's Avatar
ivorbiggun
The reason a lot of you are having bad changes is because you followed the instructions that came with the B+M.
Try assembling it on kitchen floor(including the long rod),then offer up the clamp (don't tighten yet)
to shifter shaft THEN bolt unit to the floor of vehicle. Then and only then
tighten clamp on shifter shaft/this ensures that it all bolts up nice and 'square' and each shift should be as smooth as me!
Good luck.
P.S.
If your box is a little 'doughtful' a little 'slick 50' also works wonders.
Old Aug 10, 2006 | 09:47 AM
Taylor's Avatar
Taylor
Well after reading this post i think that i will be putting one of these down on my list of things to get during the winter!
Kyle Langford
27
Aug 5, 2019 07:54 PM
ekjim
Aug 27, 2015 05:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
marky_g
Aug 15, 2015 10:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
