adj tca,s
Old Jul 14, 2006 | 09:53 PM
Basky's Avatar
Basky
Default adj tca,s
are they astraght swop or do you have to change anything else
Old Jul 14, 2006 | 11:44 PM
NUTS RuS's Avatar
NUTS RuS
Straight swap
There is a group buy for sierra ones currently on going in the Sierra section
Old Jul 14, 2006 | 11:54 PM
Basky's Avatar
Basky
friend of mine is havin probs getting it tracked after fitting these
Old Jul 15, 2006 | 12:00 AM
NUTS RuS's Avatar
NUTS RuS
In what sort of way ?
There should be enough adjustment for major +/- lengths if they are fitted correctly.
Old Jul 15, 2006 | 12:07 AM
Basky's Avatar
Basky
cant get the right camber on 4x4 cossie,thers not enough thread left in the track rods
Old Jul 15, 2006 | 12:20 AM
NUTS RuS's Avatar
NUTS RuS
Can you adjust the R/J or are they not rose jointed ones ?
Old Jul 15, 2006 | 12:30 AM
Basky's Avatar
Basky
they are rose jointed,got mine allready but wont fit them till he,s sorted
its 2wd mine and been told to set at between 3-6 degrees neg camber
they are both track cars
Old Jul 15, 2006 | 12:52 AM
NUTS RuS's Avatar
NUTS RuS
Did you ask the supplier for extra long ones to make it easier ?
Extra length could be left in if your running big camber settings.
I take it the track your going to be on will be very tight and twisty ?
yatta
May 21, 2016 10:31 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Mark V8
Sep 13, 2015 09:34 AM
Topjoe9
Sep 12, 2015 09:50 AM
bassboy
Aug 5, 2015 08:21 AM
