airco back in?
I have bought a pro alloy cooler 2years back...it works really good...
But i have seen radtec does a set (rs500ic, radiator and slim fans) so i can use an airco...
But i pulled my airco radiator out with to much force so its not good...
Is it reversable to the airco back in....
What about the stuff which goes in the airco system...
Anyone experience with this..
Thanks...
Thanks...
anything's possible by someone who knows what they're doing.
if not done properly, the compressor will end up being damaged which gets expensive.
if you have an a/c condenser fitted, you must have electric fans on it controlled by the a/c circuit.
Thrush depends where you come from
uk it's sometimes a/c or aircon, germany klima etc, etc
JK12
33
Apr 26, 2021 12:09 PM
