Quick Amal Valve question
Old Jul 14, 2006 | 07:35 AM
rstoughy's Avatar
rstoughy
Default Quick Amal Valve question
Just a quickie folks.
The Amal Valve on the 4x4 saff cossie, should you hear it clicking while revving the engine?
I'm pretty sure that it should only work on boost and not while sitting still just revving the engine
Am i right?
If its clicking dose that mean its knackered?
Cheers for any info.
Old Jul 14, 2006 | 07:47 AM
Sticky.'s Avatar
Sticky.
Should only hear it click when the ignition is on stage 2 mate not when revving.
Old Jul 14, 2006 | 08:18 AM
Stu @ M Developments's Avatar
PassionFords Creator
Default Re: Quick Amal Valve question
Am i right?
Depends on the boost strategy mate, some maps will pulse it at around 3000rpm at approx 2hz to smooth the boost climb on 4x4s. Some of my strategies are programmed this way.
Old Jul 14, 2006 | 08:19 AM
rstoughy's Avatar
rstoughy
Cheers Paul thats what i thought.
The thing is clicking like mad while the engine is being revved up so im thinking that it might be something else thats the problem.
Old Jul 14, 2006 | 08:52 AM
Sticky.'s Avatar
Sticky.
Mine did the exact same thing, change dthe amal valve and was ok for a few days. Turned out it was the connections, so replaced them and new wiring.
Old Jul 14, 2006 | 09:03 AM
rstoughy's Avatar
rstoughy
Stu,
Thanks
The guy has just bought the car and has been told that it has a stg1 Superchip fitted so i think he prob has to change that out 1st so he knows just exactly what he has.
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
Bransby
Sep 11, 2015 01:09 AM
markk
Sep 9, 2015 08:11 AM
andrewmctiernan
Sep 8, 2015 03:05 PM
cossirob
Sep 3, 2015 09:17 PM
