Cam question - Chip maybe?!?!?
Old Jul 14, 2006 | 07:30 AM
Franco's Avatar
Franco
Default Cam question - Chip maybe?!?!?
MAYBE A QUESTION FOR CHIP.....................
Want to strip off the sump tomorrow, so i can start cleaning the block etc ready for a lick of paint.
One question!
I have one cam that has been removed thus leaving the tappets exposed (dont worry the cam covers on!) but i'm worried about turning the engine over on the stand like this.
I dont want to end up with the tappets falling out & getting mixed up.
Drama queen i know! But i'd rather ask stupid questions than stick posts up saying i've fucked it!
Old Jul 14, 2006 | 07:57 AM
MONSTER's Avatar
MONSTER
just remove the followers then!, use a valve grinding stick with the suction cup ends to get the followers out, but make sure you make a note of which ones go where
Old Jul 14, 2006 | 09:30 AM
St3V3_C's Avatar
St3V3_C
As above. DON'T use a magnet to get them out.
Old Jul 14, 2006 | 09:39 AM
DaveEscos's Avatar
DaveEscos
Old Jul 14, 2006 | 09:50 AM
Franco's Avatar
Franco
Doh did fancy taking the head to bits being honest.............
I'm on a downward spiral with this engine!
Old Jul 14, 2006 | 09:52 AM
St3V3_C's Avatar
St3V3_C
Use a bit of something under the cam caps to hold them in place then? Bit of 2x1 wood?
but could actually work...
Old Jul 14, 2006 | 09:53 AM
Sticky.'s Avatar
Sticky.
Dont forget to drain the oil awsell
Old Jul 14, 2006 | 09:54 AM
Franco's Avatar
Franco
Oil................
All i have in my head is water mate!
Old Jul 14, 2006 | 10:07 AM
St3V3_C's Avatar
St3V3_C
And a whole lot of air...
Oh, you mean the engine, nevermind...
Old Jul 14, 2006 | 10:08 AM
Franco's Avatar
Franco
Air................nah thats deffo leaving the roost mate!
Sticky.'s Avatar
Sticky.
Oil................
In the sump you div
foreigneRS's Avatar
foreigneRS
Testing the future
if the cam is removed, all valves on that side will be closed so nothing to worry about
the tappets cannot go anywhere anyway.
and it wouldn't matter if they were mixed up in my experience
Old Jul 14, 2006 | 10:11 AM
St3V3_C's Avatar
St3V3_C
I thought that at first, but he means turn the whole engine upside-down on the stand so the lazy git can take the sump off without bending over...
Old Jul 14, 2006 | 10:12 AM
Franco's Avatar
Franco
Old Jul 14, 2006 | 10:13 AM
St3V3_C's Avatar
St3V3_C
lazy git
At least you are honest I guess
Old Jul 14, 2006 | 10:14 AM
Franco's Avatar
Franco
as the day is long!
Old Jul 14, 2006 | 10:22 AM
I was reading this viewing it the same way as ForeignRS, wondering why turning the engine over would matter, lol
Just take them out and keep them in order.
Im really not convinced by the arguments against using a very weak magnet on them though TBH, ive done it so many times in the past with other engines and not had a problem, but a valve grinding stick tends to be my weapon of choice just in case there is some truth in the paranoia.
Old Jul 14, 2006 | 10:24 AM
Franco's Avatar
Franco
Cheers lads!
Another question (off a list of many!) answered!
Eagle's Avatar
Eagle
Super Moderator
why not a magnet i can hear many people asking ???
Old Jul 14, 2006 | 10:25 AM
Franco's Avatar
Franco
Go on then Pete...........
Why not a magnet!
Old Jul 14, 2006 | 10:26 AM
foreigneRS's Avatar
foreigneRS
Testing the future
oh yeah, "turn it over" as in turn it upside down, not rotate the crank
would help if he could speak proper english wouldn't it?
as said, it doesn't matter if they get mixed around unless the head is extremely worn so just take them out with a suction tool (the type normally used to grind in valves)
Old Jul 14, 2006 | 10:27 AM
Eagle's Avatar
Eagle
Super Moderator
Why not a magnet!
fucked if i know ..... and no doubt plenty of others are thinking the same .. so why not then mate ???
Old Jul 14, 2006 | 10:29 AM
foreigneRS's Avatar
foreigneRS
Testing the future
the reason that you don't use a magent is because if you do, you will magnetise the follower surface. that will then hold onto any particles floating about that will get between the follower and the cam lobe where you have very high pressures and a thin oil film and the cam lobes will wear very quickly
The thoery with the magnet being a problem is that you magnetise and followers and therefore in the future any tiny bits of swarf in the oil that go through them will be attracted to them and stay there, thus causing problems with their operation.
Old Jul 14, 2006 | 10:30 AM
Snap
Old Jul 14, 2006 | 10:31 AM
Eagle's Avatar
Eagle
Super Moderator
see .. now everyone who reads it will know
including me ...
cos elle
Sep 25, 2015 09:52 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
Chopshop85
Sep 12, 2015 06:42 PM
grishenko45
Sep 9, 2015 12:58 PM
