CO Screw Seized and Rounded Off
Old Jul 9, 2006 | 08:52 AM
aldy's Avatar
aldy
Default CO Screw Seized and Rounded Off
Hi, my S2 ERST has just failed MOT as my CO can't be adjusted as the screw has seized and been rounded off at some point. Can the metering unit be stripped apart and the screw replaced
Old Jul 9, 2006 | 09:57 AM
SafeChav's Avatar
SafeChav
You can certainly give it a go you've got nothing to lose, but ive had a go at undoing the screws holding the arm inside and they weren't coming un done for shit.........and the mixture screw is a special screw from what i remember, not like a normal screw.
If you fail you have 2 options:
A) New metering head and/or housing
B) EFI (you know you want to )
Old Jul 10, 2006 | 06:45 PM
Rick's Avatar
Rick
give her an air leak for the mot
Old Jul 10, 2006 | 07:48 PM
SafeChav's Avatar
SafeChav
never thought i would hear such a rough suggestion from yourself.
Tut tut
Old Jul 10, 2006 | 08:59 PM
Rick's Avatar
Rick
Old Jul 10, 2006 | 11:09 PM
Hyper's Avatar
Hyper
Anoys me to hell, got for an Mot and theres your tune down the drain.
Old Jul 11, 2006 | 09:18 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Bring it over and ill get the screw out for free.
Done it loads of times as it is common.
Regards
Old Jul 11, 2006 | 10:23 AM
SafeChav's Avatar
SafeChav
Fairplay
Old Jul 11, 2006 | 12:16 PM
Rick's Avatar
Rick
Old Jul 13, 2006 | 06:51 PM
aldy's Avatar
aldy
Thanks for the offer Jano but with half a tin of WD40 and a bit of patience I managed to free the screw, Car has now passed MOT and is back on the road.............................and thats just opened up a whole load of new problems
Old Jul 13, 2006 | 06:52 PM
SafeChav's Avatar
SafeChav
Fantastic news
Whats the problems now?
Old Jul 13, 2006 | 07:01 PM
aldy's Avatar
aldy
Bit of a misfire when going up through the rev range while driving, a few rattles, absolutely no oil pressure, boost gauge reads -8 at idle don't know if thats right or not.............but just drivin 20 miles with the biggest smile ever
Old Jul 13, 2006 | 07:13 PM
SafeChav's Avatar
SafeChav
I wouldn't expect it to drive far with no oil pressure.
Didn't you already change the pump?
Old Jul 13, 2006 | 07:26 PM
aldy's Avatar
aldy
Yeah I changed and checked everything but still no pressure, so its gonna be good bye to this engine and hello new one already on bench in garage, I just wanted a little fun before the big bang
Old Jul 13, 2006 | 07:28 PM
SafeChav's Avatar
SafeChav
Does it sound tappy as fuck when it runs or does it sound quiet and nice?
Old Jul 13, 2006 | 08:06 PM
aldy's Avatar
aldy
It doesn't sound tappy at all its all nice and quiet
Old Jul 14, 2006 | 08:19 AM
SafeChav's Avatar
SafeChav
Then your gauge or something to do with it is shit. No oil pressure = no oil in the hydraulic lifters = noisey as fuck engine
Does your oil light go out? What type of gauge do you have electronic or mechanical?
Old Jul 15, 2006 | 01:16 PM
aldy's Avatar
aldy
Its a mechanical gauge and I've also fitted a new oil pressure switch the oil light comes on when the fan clicks in and the gauge reads about 5 psi
Old Jul 15, 2006 | 01:19 PM
SafeChav's Avatar
SafeChav
Hmmmmm
Very strange. see if you can borrow a PROPER oill pressure gauge to get an accurate reading, if you know what i mean it looks just like a compression tester
timsrs
Nov 13, 2018 11:48 AM
gcfcos
59
Oct 6, 2015 05:04 PM
The Youth.
Sep 30, 2015 09:59 PM
DAZZER
Sep 30, 2015 08:43 PM
stevecfrst1
Sep 30, 2015 05:18 AM
