T5 Gearbox In a Capri
Ok, can anyone help with my dilema. Has anyone fitted a T5 Cossie box in a Capri, what cross member do you use ? I've put the box on the Cossie engine, jacked it up into position,the Capri cross member looks too far away from the body. I know i'd have to put new holes in it to make it fit, just a bit miffed at how far away the cross member is from the body...have I missed summit?
Any help would be huuuuuuuuugely helpfull
Ian, u need to cut a hole in tunnel to accept T5 change mech this raises the box up and the engine is up a the right angle
u then have to fab up a cover for top of gear lever if i get chance i will post a pic up.
Paul
u then have to fab up a cover for top of gear lever if i get chance i will post a pic up.Paul
chowfornow
14
Jan 5, 2019 09:01 PM
