building a zvh engine
alrite folks here we go, i have a series 1 that im going to build the engine myself ive changed pistons etc myself before but ive never had a block bored out before so im not sure how much all you 2.1 zvh folks exact bore is & do you buy pistons the exact same size the bore is, im not boring it out myself i just need the measurements to give to the machinist & the size pistons i nead to buy... thanx
Your best bet is to not bother.
Either stick with a CVH or build a correctly specced Zetec Turbo.
If you are still adamant you want a ZVH then I am sure someone will post up what you will need to build one.
This site will help you.
http://www.quantums.info/
JoeyBoyden
Jan 4, 2024 02:36 PM
blackbeautyzetec
Sep 11, 2015 03:10 PM
muz
Aug 16, 2015 12:57 PM
