How to test actuator?
Hey, i'm hoping that someone might be able to tell me how i can do a test on my actuator to see if it's working correctly as i'm loosing boost.
u test the actuator by putting a miti-vac guage on it and pump the guage up to add vacum or pressure and should see the rod move, also if the guage on the miti-vac drops straight away then the diaphram will be split inside the actuator, indicating its fooked
TPM961
15-01-2018 10:50 AM
