Fuel line Noise
Old Jul 5, 2006 | 08:07 PM
mattxr3i's Avatar
mattxr3i
Default Fuel line Noise
Hi there
I have an 89 mfi escort xr3i. i have a high pitched sqeal comign from my fuel lines in the engine bay. I have replaced the following with brand new items: Fuel accumulator, Fuel Filter and Fuel distributor, all to no avail. The noise is only apparent at idle and when the foot is taken off the throttle. When applying the gas no noise.
I have also had the problem where with sustained pushing, the car pinks and gets steadily worse the more you push on. Timing is fine, spark plugs are fine as well
Any ideas?
Old Jul 7, 2006 | 02:31 PM
costina's Avatar
costina
Live long and prosper!!
do you run a power boost valve? if you do its that, or your standard pressure reg.
have heard a similar noise and it was that
check you fuel pressure as this maybe the cause of pinking etc
Hope this helps
Old Jul 8, 2006 | 07:48 AM
SafeChav's Avatar
SafeChav
Fuel pump could also be getting tired.
Old Jul 8, 2006 | 01:56 PM
paconassa's Avatar
paconassa
Hope this helps
on mfi's its not possible to mount a pbv...
if your car pinks (and if everthing else is ok) youll have to set up the fueling... most probably poor mixture...
good luck
JK12
33
Apr 26, 2021 12:09 PM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
kevin36
Sep 8, 2015 12:23 PM
rsturbo27
Sep 5, 2015 05:08 PM
