Fitting a swirl pot to a series 2 escort turbo...
Old Jul 5, 2006 | 07:42 PM
spadey's Avatar
spadey
Default Fitting a swirl pot to a series 2 escort turbo...
Ok so my latest ebay bargain is a bailey swirl pot... Problem is it doesnt come with any pipes.. First question please can someone tell me where and how it goes? Do I need different pipes or a blankin thing for the thermostat? Bassically how and where do I fit it? Thanks for your great help in advance once again....
Old Jul 5, 2006 | 10:31 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
An aftermarket swirl pot on an RST is pointless as they are fitted with one as standard!!
If you must fit an aftermarket one, the best bet is to also get a normal CVH Thermostat housing, then fit it with the aftermarket Swirl pot.
Old Jul 6, 2006 | 05:57 AM
spadey's Avatar
spadey
Default swirlpot
Hi mate, so where bouts are they as standard? can I not just replace the standard one with the alloy one? Any help is appreciated.
Old Jul 6, 2006 | 06:46 AM
antony215's Avatar
antony215
Escort Rs Turbo
Block the hole on top off on your Thermostat housing then the pipe that was on there connect to the top off the swirl pot then you need to cut the pipe that goes from the Thermostat housing to the rad and put the swirl pot in line.
This is the part of the pipe you need to cut out cut the bend out of it and put the swirl pot in
Old Jul 7, 2006 | 06:30 PM
spadey's Avatar
spadey
Default swirl pot
Ah I see mate, so do they have one on as standard? And am I wastin my time puttin one on or will it take out the bubbles and make the coolin system more efficient? Cheers
Old Jul 7, 2006 | 06:32 PM
Oranoco's Avatar
Oranoco
Yes you're wasting your time the ERST and FRST have aswirl pot built in as standard in th etop of the thermostat housing. It might look pretty but it's going to do fuck all. Sorry mate
Old Jul 7, 2006 | 07:44 PM
LEE-RS's Avatar
LEE-RS
Custom
as said total waist of time sell it on
Old Jul 8, 2006 | 02:31 PM
s2turbo's Avatar
s2turbo
Default tahnks
thanks for this post as i was just about to go out and buy one
pennies saved
Billy_RS
16
Oct 11, 2025 09:41 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
Vincereese
Aug 16, 2015 06:38 PM
RsS2daz
Aug 14, 2015 05:26 AM
RSMK4TURBO
Was It You?
Aug 3, 2015 09:21 PM
