WHICH INDUCTION KIT?
Old Jul 5, 2006 | 12:50 PM
BIGEVILRTS's Avatar
BIGEVILRTS
Default WHICH INDUCTION KIT?
hey just wondering what induction kit is best for the s2 erst im guessing most people have k&n but i was thinkin of going for something a bit different any ideas? and also wheres the cheapest place for a GRS intercooler the big one
thanks
Old Jul 5, 2006 | 02:21 PM
reality's Avatar
reality
The best induction kit is the stock airbox.
antony215's Avatar
antony215
Escort Rs Turbo
Best to get a standard airbox with a k&n panel fillter in because the cone fillters suck in alot of hot air which you dont want.
Old Jul 5, 2006 | 03:31 PM
BIGEVILRTS's Avatar
BIGEVILRTS
well thats what i have but only standard ford filter in so dont the k&n's have a heat shield with them and the posistion of them i thought they would get a good cold air feed??
Old Jul 5, 2006 | 03:45 PM
addiction's Avatar
addiction
k&n doesnt come with a heat shield but you can get one from AS autospecialists which will help reduce warm air intake.
the only place to get a GRS from is GRS direct
Old Jul 5, 2006 | 04:51 PM
s2turbo's Avatar
s2turbo
Default if
if you dont want a stock airbox what would be the best cone to fit
Old Jul 5, 2006 | 04:53 PM
gambit's Avatar
gambit
Default induction
standard airbox with k&n panel filter all day long, however drill the airbox and have an air duct ducting air directly to the box and you cant really do better than that.
Old Jul 5, 2006 | 07:36 PM
steven botes's Avatar
steven botes
made up a bracket to fit a cone filter behind the passenger side headlight , nice big reinforced hose to the turbo inlet , good inductiom noise!
Old Jul 5, 2006 | 07:40 PM
s2turbo's Avatar
s2turbo
Default as u can see in my sig
as u can see in my sig the inner headlight has been removed and the filter has been moved to right behind it. now its time to change the filter and i just want to know what one people recommend
Old Jul 5, 2006 | 10:29 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
There REALLY is no better filter for an MFi RST than the standard Ford airbox with a K&N Panel filter in it.
The engine bay of any turbo car is VERY hot, but the RST engine bay is also quite tight, so suffers even more.
A heat-shield is pointless for a cone filter as the temperature of the whole engine bay is hot.
So, if noise is more important than performance, then fit your induction kit and also put a dump valve on.
Old Jul 5, 2006 | 10:35 PM
EssexMikeSi's Avatar
EssexMikeSi
ive got a cossie group A induction cone for mine, bearing in mind tho that mines been converted to efi and cos m-ment, but recently ive been thinkin that maybe i shouldnt have got such a big filter as its gona draw even more hot air
Old Jul 5, 2006 | 11:09 PM
Christian and Beccy
#1 in Spelling Club
I also use a GpA filter, but mine is tucked down low. You have to take care not to have it so low that it sucks in water as that would end in tears!!
Old Jul 7, 2006 | 05:22 PM
s2turbo's Avatar
s2turbo
Default sofar
so far there has been plenty of posts in reply to thisbut allhave been irrelevant
surely someone must have a manufacturers name on there mind that make the dogs danglies of filters
all i require is......
a. should i use a cotton, foam or steel gauze filter
b. what manufacturers people recommend
Old Jul 7, 2006 | 06:14 PM
Christian and Beccy
#1 in Spelling Club
Default Re: sofar
How so? We have given advice according to our own experiences. In my opinion K&N make THE best filters. Full stop. But why you would want to run a filter that everyone has told you will cost performance god only knows.
Your choice.
It's the same as if someone came on here saying that they want to machine 5mm off their pistons. It would only be right for those better educated among us to advise against it.
Old Jul 7, 2006 | 07:22 PM
reality's Avatar
reality
I find K&N's left far too much shit through, you can see the pitting on your compressor blades..
I prefer pipercross..
Old Jul 7, 2006 | 11:04 PM
Christian and Beccy
#1 in Spelling Club
In actual fact, in my experience it's the foam filters that let too much through. HKS being the worst offenders.
Providing your K&N is in good condition and you keep it cleaned/oiled with the right stuff it will be superb.
Old Jul 8, 2006 | 02:30 PM
s2turbo's Avatar
s2turbo
Default cheers
i didnt mean to offend anyone but i was after a quick straight to the point answer a my car is in bits all over the yard and im trying to get it running asap,
Old Jul 9, 2006 | 03:11 PM
addiction's Avatar
addiction
K&N over pipercross anyday from my experiance. pipercross tear far too easily and as Christian says foam filters seem to let more dirt particals through.
Old Jul 9, 2006 | 03:42 PM
iamrab's Avatar
iamrab
right what about this ....
if your have a front mounted intercooler what does it matter about the heat ?? think about it the turbo is sucking the air into the turbo from the airfilter then it sending it around the intercooler(front mounted) for cooling and then into the charge carrier to the throttle body ....so surely all u want is some thing that as derestricted as possible so that the turbo can suck as hard as possible ?? i know in an na car with no intercooler its very important but in a turbo car the turbo is roasting anyway so it wont matter how cold the air into it is bacause once its in the turbo its gonna get crazy hot anyway ??
i may be totally wrong and if i am please explaine cos its intresting
Old Jul 9, 2006 | 03:47 PM
kiddie's Avatar
kiddie
thats a fair point mate!
Old Jul 9, 2006 | 04:38 PM
reality's Avatar
reality
It's not a fair point, it's complete rubbish. The air temperature that enters the engine is the total of everything before it, so the hotter any one part is (turbo, intercooler, ambient, etc.), the hotter the total will be.
Old Jul 9, 2006 | 05:02 PM
Chris69's Avatar
Chris69
as far as induction kits go think K+N's do the best job of filtering etc but i love the sound of the others such as the pipercross ones
i think u'll find the temp of your air being sucked in will proportionally effect the temp of ur turbo itself therefore causing the air to be hotter once entering the intercooler and exiting the intercooler.
essentially the denser the air in the whole system the better otherwise you'll get accumulative temperature increase.
Old Jul 9, 2006 | 05:32 PM
rugged rick's Avatar
rugged rick
hello chaps dont want anyone to think im hijackiing this thread but i too was going to go down the route of drilling the airbox as i remember reading a few years back in performance ford that this is a very good option (cheap too),my question is whereabouts on the airbox do u drill the holes and how many .any pics would b great if anyone has any back to topic
cheeRS rick e
Old Jul 9, 2006 | 05:57 PM
Chris69's Avatar
Chris69
don't bother drilling it, take the top off, open the round whole so its then the entire front of the the airbox and add a K+N panel filter.
if u drill it u risk getting water into the system due to the positioning of the vent on ur bonnet
Old Jul 9, 2006 | 06:10 PM
dave_y's Avatar
dave_y
this is what i shall be doing in the near future, i think T28 RST has done a similar thing.
Also by getting rid of the metal plate under the vent should help cooling surely?
Old Jul 9, 2006 | 06:25 PM
Christian and Beccy
#1 in Spelling Club
Getting rid of the metal plate will make it prone to take water in.
Old Jul 9, 2006 | 07:17 PM
EssexMikeSi
mines just behind my headlight. perfect if i decide to get a scoop later on
Old Jul 9, 2006 | 10:28 PM
dave_y's Avatar
dave_y
you don't need a metal plate if you have a standard airbox though do you.....?
Old Jul 10, 2006 | 09:35 AM
Chris69's Avatar
Chris69
i would have thought so as it lets more air under the bonnet on the move, doing it this way it shouldn't let any more water in than the standard airbox does
Nov 1, 2015 06:53 PM
