Question for you all
Old Jul 4, 2006 | 12:39 AM
thelynx's Avatar
thelynx
Default Question for you all
http://cgi.ebay.co.uk/Cosworth-3-doo...QQcmdZViewItem
Does anyone know if these can be made to fit my s2? And under standard 15's? Are they any different to the saph 2wd?
Old Jul 4, 2006 | 05:31 AM
antony215's Avatar
antony215
Escort Rs Turbo
They can be made to fit but not under the standard s2 wheel's.
Old Jul 4, 2006 | 07:34 AM
HORNETS7's Avatar
HORNETS7
why not?
ive got 283mm cossie discs on my s2 under 15 " rims!
unless the 4 pots are slightly bigger in depth but i wouldn't think so
Old Jul 4, 2006 | 09:47 AM
antony215's Avatar
antony215
Escort Rs Turbo
Originally Posted by HORNETS7
why not?
4 pots need some machining to be done either on the hub or calipers (about 4mm i think) and a set of longer brake lines made up for them also depending on the size of wheel you are using you may need to use a spacer to clear the caliper. Also the holes for the caliper bolts on the hub need to be tapped.
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
