S2 running problem - can u help?
When the car has sat for a few days it starts as normal but after a couple of minutes driving it cuts out and just turns over but doesn't fire up. When it does it sounds like it's running on 3 and sits and chugs away then cuts out again. This only happens when it's sat for a while and everyday use is very reliable.
Any ideas?
Any ideas?
Kev had a similar problem with my old S2, the problem was a combination of a nick in a Ht lead which resulted in an ineffective spark to the plug, which in turn casued the plug to run rich.......hows your plugs/leads?
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
