4x4 Cos Misfire
Old Jun 28, 2006 | 09:52 PM
J9BBY's Avatar
J9BBY
Default 4x4 Cos Misfire
I've got a misfire. It only comes in further up the rev range.
The car has a stage three set up with switchable boost between 10 and 23 psi.
When on 10psi the car stutters lightly at around 5500rpm - not very noticable.
When on 23psi the car stutters heavily from 4000rpm onwards - very noticable.
Any suggestions?
My thoughts were;
1. Spark being blown out
2. Crank sensor faulty
Cheers,
Pete.
Old Jun 28, 2006 | 09:55 PM
reality's Avatar
reality
Same old crap..
Plug gap..
Crap leads..
Bade rotor arm or cap..
I'd try leads first.
Old Jun 28, 2006 | 10:03 PM
J9BBY's Avatar
J9BBY
Leads are new.
Plugs cleaned and gapped to 1mm.
Distributor cap and rotor arm new.
Old Jun 28, 2006 | 10:15 PM
J9BBY's Avatar
J9BBY
Also forgot to mention, maybe not related but once the car is up to temp the fans come on and stay on until I switch car off.
Old Jun 28, 2006 | 11:11 PM
jon@work's Avatar
jon@work
try 0.6mm
Old Jun 29, 2006 | 09:07 PM
KSA-Cossie's Avatar
KSA-Cossie
Then give the crank sensor a good clean.
Old Jun 29, 2006 | 09:53 PM
J9BBY's Avatar
J9BBY
Cheers. I'll try these on Saturday
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
