charge carrier pipe
Old Jun 27, 2006 | 06:56 AM
Hrsturbo's Avatar
Hrsturbo
Default charge carrier pipe
for a S2 is any one running a carbon fibre one??
if so, where ya get it from??
if not, where can I get one made up?
that's got to stop the air heating up quite a bit!
Old Jun 27, 2006 | 06:59 AM
reality's Avatar
reality
Hansell Composites could make you one, but it'd be expensive.. The aluminium one doesn't cause the air to heat up when you're flat out..
Old Jun 27, 2006 | 07:04 AM
Hrsturbo's Avatar
Hrsturbo
is ther any carbon fibre rocker covers available also?
wanna go big with keeping charge air as cold as I can after it comes out my front mount!
Old Jun 27, 2006 | 07:07 AM
reality's Avatar
reality
Yeah, search these forums, one guy was making CF cam covers.. Neither of these things will make any difference to your air charge temp..
Eagle's Avatar
Eagle
Super Moderator
depends on what problems you are having ...
if its excessive act's then bigger intercooler will help ..
also try exhaust wrap on the carrier pipes ..
i used a length of ducting hose on mine (building air con) lowered by about 5 degrees tho... but had a huge grs so was already at 40 degrees
Old Jun 27, 2006 | 07:13 AM
Hrsturbo's Avatar
Hrsturbo
I'm not having any temp probs! I just fitted my front mount and like spending money lol.
the charge pipe always get so hot and can't touch it so thought this wouldn't help the air going throught it!
so exhaust wrap will help keep it cool and not keep it hot for longer once its hot??
stephenb4506
33
Oct 2, 2015 06:25 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mpilk
Sep 27, 2015 09:21 AM
