small turbo esccoss cam belt timing marks ???
Old Jun 26, 2006 | 05:59 PM
3drbadboy's Avatar
3drbadboy
Default small turbo esccoss cam belt timing marks ???
can someone tell me the posisition of the dizzy on a small turbo esccoss when fitting a new belt please there is a little window in the dizzy but not shore what marks you line up cheers! ant
Old Jun 26, 2006 | 07:24 PM
3drbadboy's Avatar
3drbadboy
bttt
Old Jun 26, 2006 | 08:41 PM
3drbadboy's Avatar
3drbadboy
anyone
Old Jun 26, 2006 | 09:03 PM
Dans S2's Avatar
Dans S2
Don't know why I'm reading this post Like i'm gonna know the answer
Old Jun 26, 2006 | 09:07 PM
Disabled Account's Avatar
Disabled Account
Default Re: small turbo esccoss cam belt timing marks ???
Ant, as you look through the perspex window of the phase sensor (it's fitted where the dizzy is on other Cossies), you will see the white section that is HIGH or the LOW section (also white).......it is like the top of a castle. Anyway, as you turn the pulley (clockwise) look through the perspex to see when the high section is JUST starting to end (before it becomes low) as it passes the marker line, that is the EXACT point for correct phase setting.
Difficult to explain in words, but you will see what I'm getting at in practice - good luck
Old Jun 26, 2006 | 10:06 PM
3drbadboy's Avatar
3drbadboy
cheers doug i think i understand what ya saying i quess you meen the marking in the middle of the site glass ?
Old Jun 26, 2006 | 10:16 PM
GARETH T's Avatar
GARETH T
as doug says
this might help though
Old Jun 26, 2006 | 10:17 PM
Disabled Account
Yes there is a marking in the middle of the sight glass, as you turn the pulley slowly clockwise by hand, notice that the circular part beneath the sight glass has a half section that is raised (high) and the other half is lower. The correct phase point is exactly as the raised part just starts to run past the sight glass marking.
Old Jun 26, 2006 | 10:20 PM
3drbadboy's Avatar
3drbadboy
spot on i understand cheers! boys
Old Mar 8, 2008 | 06:37 PM
Azrael's Avatar
Azrael
I just found this thread, uhh I am now saved
Old Mar 9, 2008 | 09:11 AM
GARETH T's Avatar
GARETH T
i was just about to find my pics, then i seen i had posted,,, must be an old thread LOL
Old Mar 9, 2008 | 09:38 AM
Azrael's Avatar
Azrael
It is old I think, I found it through search engine
cos elle
Sep 1, 2015 06:48 PM
muz
Aug 16, 2015 12:57 PM
mpilk
Aug 12, 2015 09:40 PM
taylora1409
Aug 12, 2015 12:06 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
