When building an engine up...
i have noticed that both my block and head have a slight burr on them, is it best to remove this before assembly as im guessing it will cause hot spots and potentially melt the fucker?
is ok to just run a bit of emery cloth around the bores and the edge of the combustion chamber on the head?
and lastly, as the engine will be all built up, it still wont be started for several months while the rest of the car is getting sorted out, am i best off using some of that engine builders grease and slap a load on instead of just using oil, as that will possibly drain away wheres the grease will stick to everything.
i think thats it for now lol
thankyou please
thankyou please
why, cos im inpatient lol
got all these bits kcicking around that sooo need to go together.
i guess wet and dry would be fine too, its only where the block and faces have been skimmed that it feels a bit sharp
might be ok as it is tho
ive built an engine im not using for at least a year, i just keep it well lubed up in the mean time and stored in a warm and dry place
well, mine will be done in the kitchen
chip, doug imported them from the states for me, Siemans jobbies, and were a lot less than a set of greys!!
ill let doug tell you how much ŁŁŁ if he wishes, as i dont know if he will be selling them etc
sounds interesting doug?
where from, and how much, sounds ideal for the vauxhall lads!
Drop me a line on MSN later tonight and i will tell all.
JoeyBoyden
Jan 4, 2024 02:36 PM
