Special ford tool suppliers?
Old Jun 25, 2006 | 03:37 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Default Special ford tool suppliers?
I need to get a special tool for removing the input shaft locking collar on the MT75 gearbox (2wd or 4x4, both the same nut) - its some large socket that is very deep, does anyone know where I can get one of these tools, apart from Ford who would charge a fortune
Old Jun 25, 2006 | 03:47 PM
GARETH T's Avatar
GARETH T
sounds like you need a deap "box" spanner
ebay?
Old Jun 25, 2006 | 03:51 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Box spanner won't be good Gareth - the socket needs to be 12 sided and not 6
I've searched on all the usual tool supplier webbys and can't find anything
Maybe, If i can get a normal 12 sided socket, get jiggy with the angle grinder, weld in some box section, and then weld the top onto that, I'll have a nice deep socket
The next question is, what size is the socket I need
Old Jun 25, 2006 | 03:54 PM
GARETH T's Avatar
GARETH T
get jiggy mate
Old Jun 25, 2006 | 04:15 PM
DazC's Avatar
DazC
It's about Ł50 from Ford IIRC.
http://www.etis.ford.com
Click services then special tool catalogue at the top.
Failing that, make one with a socket and a peice of scafolding tube!!
Old Jun 25, 2006 | 04:17 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Daz - just been reading on Interford, its a 46mm socket, but you can remove the nut by tapping it round a bit then spinning it off by hand - should save me some money
Then the rest of the gearbox should just pop apart once the bolts holding the case together are undone, with a bit of luck
Old Jun 25, 2006 | 04:38 PM
BlueSmoke's Avatar
BlueSmoke
PassionFord's crazy fool!
Good luck Paul
Old Jun 25, 2006 | 04:46 PM
filthyrichie's Avatar
filthyrichie
company called churchill provide the tools for ford
Old Jun 25, 2006 | 04:58 PM
dojj's Avatar
dojj
Resident Wrestling Legend
taps made one, he might even be able to show you a pic of it
Old Jun 25, 2006 | 05:03 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Dojj - just done a search on Interford - found all the pics of Tapp's tool (oooeer )
With regards to removing the front case, which 5th gear bolt do you remove, and which one do you leave in?
Old Jun 25, 2006 | 05:12 PM
dojj's Avatar
dojj
there are 2 bolts that hold the reverse gear in place
one either side of the box halfs (front and rear)
let me go and get some pics of what i mean
if you undo both then it's a bit tricky to get it all back together again
and whatever you do DON'T take the gear selector locater thing apart, it's a right pain in the butt to get back together again, a mistake i learnt to regret
Old Jun 25, 2006 | 05:17 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Ahh yes, i'm with you, If i leave it on the tail section, then the case should come off with no cogs inside it
job for tomorrow
Old Jun 25, 2006 | 05:26 PM
dojj's Avatar
dojj
you want to remove only one of the bolts that are seperatly circled on the lower part of the box, i made the mistake of removing the bolts on the top too, not good
you'll also need to reset the perload on the countershaft
Old Jun 25, 2006 | 05:56 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Cheers Dojj - much appreciated
How do you reset the preload on the countershaft?
Old Jun 25, 2006 | 07:03 PM
dojj's Avatar
dojj
not sure
something about putting a certain amount of torque on the bolt and then slackening it off a little
i think mob has the data you need
Old Jun 25, 2006 | 08:11 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Cool stuff, does Tony come on msn?
Old Jun 25, 2006 | 08:22 PM
dojj's Avatar
dojj
occasinaly
Old Jun 25, 2006 | 08:29 PM
Graceland's Avatar
Graceland
Team HOTHOT!
whats his msn address?
Old Jun 25, 2006 | 08:38 PM
dojj's Avatar
dojj
bloody hell fire man!!!! for some reason the forum is a little slow today but you seem to be quetioning everything before i've thought of the answers
pm on the way
Billy_RS
16
Oct 11, 2025 09:41 PM
ekjim
Aug 27, 2015 05:20 PM
155lee
14
Aug 22, 2015 12:15 PM
borboyous
Aug 22, 2015 11:17 AM
