Just tested my MAF sensor results inside!
Old Jun 24, 2006 | 01:49 PM
Rene's Avatar
Rene
Default Just tested my MAF sensor results inside!
OK just tested with me mate the MAF sensor as we couldnt find any other problems regarding high CO
Now we pulled the intake hose half off the MAF sensor and we rapidly saw the CO% dropping like a rock! tested it a few times and same occurs.
MAF sensor fooked i reckon???
Can i clean it or just stick a new one in?
Rene
Old Jun 24, 2006 | 03:56 PM
Mark Shead's Avatar
Mark Shead
Every Small turbo with running problem I have seen has aways been the AFM, Does it have a cone filter on it.
Mark
Old Jun 24, 2006 | 04:42 PM
Rene's Avatar
Rene
yes mark it has but as i disconnected it it stalled and the engine went out so figured it might be working ... looked inside and didnt really lkooked dirty .. but i reckon its fooked then ?
Old Jun 24, 2006 | 04:46 PM
Mark Shead's Avatar
Mark Shead
Check the cone filters breather return most I have seen go straight in to the AFM measuerment hole not good for reliabilty.
Mark
Old Jun 24, 2006 | 05:04 PM
Rene's Avatar
Rene
it sits like this mark:
Old Jun 24, 2006 | 05:13 PM
Mark Shead's Avatar
Mark Shead
That looks fine.
Mark
Old Jun 24, 2006 | 05:17 PM
Rene's Avatar
Rene
But given then info from the first post mark CO dropping when i have the hose a bit off the MAF and the CO is spot on is that telling that the MAF is fooked then yes?
is there a way to clean it or should i stick a new one in?
Old Jun 24, 2006 | 05:22 PM
Jim Galbally's Avatar
Jim Galbally
carb cleaner the feck out of the hotwire element (take the sensor bit off it 1st)
see if it makes it any better
Old Jun 24, 2006 | 05:23 PM
Rene's Avatar
Rene
JIm was thinking of that but i also heared that carb cleaner doesnt dry without any residue
Old Jun 24, 2006 | 07:22 PM
Rene's Avatar
Rene
Old Jun 24, 2006 | 07:31 PM
GARETH T's Avatar
GARETH T
im not sure goon,,,,, i would have a go with the carb cleaner
Old Jun 24, 2006 | 07:32 PM
Rene's Avatar
Rene
will do before buying another see if it helps or not cheers mark, jim and last but not least Gareth might have found it then anyway
Old Jun 24, 2006 | 07:34 PM
Billabong's Avatar
Billabong
No, you shouldn't use carb cleaner. Use an electrical contact cleaner.
Old Jun 24, 2006 | 07:42 PM
Rene's Avatar
Rene
cheers for that bill fingers crossed getting it tomoz!
Old Jun 24, 2006 | 08:36 PM
Jim Galbally
any spray on shit will do
Old Jun 24, 2006 | 08:59 PM
SteveB's Avatar
SteveB
I've used brake cleaner b4 and that works
Old Jun 24, 2006 | 09:13 PM
Rene's Avatar
Rene
Cheers Steve for the tip
But since i need to get either anyway will get some contact cleaner on monday
Old Jun 24, 2006 | 09:53 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
brake cleaner works VERY well
Old Jun 24, 2006 | 09:55 PM
Billabong's Avatar
Billabong
You could probably clean it using cotton buds or a lint free cloth soaked in alcohol, gently wiped up the wire - you could fit an oiled air filter to a vehicle with an AFM, but I wouldn't do any of those either
Maybe I should have phrased it I wouldn't use any other than an electrical contact cleaner to clean a relatively fragile AFM.....
Old Jun 24, 2006 | 10:28 PM
Jim Galbally
and [b]'d[/]b just spray it with whatever aerosol propelled liquid i could find in the shed
lynx africa would work weell
Old Jun 24, 2006 | 11:35 PM
Billabong's Avatar
Billabong
Old Jun 25, 2006 | 08:15 AM
Rene's Avatar
Rene
bill like i said ive read that brake/carb cleaner dries up with leaving residue so will go for the contact cleaner just to make sure its the best option i can use
TPM961
Jan 15, 2018 10:50 AM
Fiddy
21
Sep 29, 2015 06:10 PM
timsrs
22
Sep 24, 2015 08:14 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
hopper350
Sep 4, 2015 12:53 AM
