amal valves
Old Jun 24, 2006 | 10:59 AM
kevin cozzer's Avatar
kevin cozzer
Default amal valves
Does anyone know if you need to leave the white inserts/restrictors in a new amal valve. as my old one hasent got any, and the new one has them in two of the three tube ports?
Old Jun 26, 2006 | 08:05 AM
Mr 19"'s Avatar
Mr 19"
You can adjust your boostpressure by changing these inserts. The bigger the hole in the inserts, the more boost you get. When you buy a stage 2-kit from Mountune for example, you get another set of inserts which are included in the kit,and these have a bigger hole.
Old Jun 26, 2006 | 02:40 PM
HORNETS7's Avatar
HORNETS7
sound like u got a rs turbo amal valve and u need a cossie one!?
Old Jun 26, 2006 | 09:01 PM
reality's Avatar
reality
You will want to keep the restrictors if you car has been set up with them..
steve.rst
Mar 15, 2016 08:01 AM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
rs_jim
Sep 19, 2015 08:41 PM
