rs turbo pistons
Old Jun 16, 2006 | 12:40 AM
davecosworth's Avatar
davecosworth
IM BACK
Default rs turbo pistons
hello guys do you no of any were that i can get a set of low compression pistons from for a rs turbo s2 or can i have the piston crowns skimed to low the compression cheers
Old Jun 16, 2006 | 10:07 AM
stuart collins's Avatar
stuart collins
burtons . but why u want to go low comp?
Old Jun 16, 2006 | 10:29 AM
davecosworth
IM BACK
so i can run higher boost with out reduceing the reliability
Old Jun 16, 2006 | 11:37 AM
stuart collins
im runnin 1.9 bar with no det and mine is higher than standard
Old Jun 16, 2006 | 08:17 PM
Rick's Avatar
Rick
you can't buy forged pistons for the CVH. You skim the crowns to whatever CR you require.
Old Jun 16, 2006 | 09:07 PM
reality's Avatar
reality
Of course you can buy forged pistons for CVH's..
Old Jun 17, 2006 | 06:24 PM
scotty86d's Avatar
scotty86d
Surely with higher compression you need superb managment and fuelling so nothing goes wrong. I expect the throttle response is miles better though????and low comp pistons with rings are something like 137 for cosworth each or 100 odd for mahle/accralite from burtons
JK12
33
Apr 26, 2021 12:09 PM
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
kevin36
Sep 2, 2015 06:24 PM
rsturbo27
Sep 1, 2015 09:54 PM
