Help. Dam cos engine has probs
Old Jun 12, 2006 | 05:49 PM
Taner's Avatar
Taner
Default Help. Dam cos engine has probs
Hello All.
I have a problem.
Car was running fine on new enginre build in different car.
all of a sudden loss of power and wouldnt start.
30 mins later after basically nothing it started on the button.
2 hours later decided to go for a drive . Started the car up, began to reverse off the drive and it stalled. tried to start it up and nothing. After 3 hous of checking what seemed like everything. Still no joy. Gave t a rest for an hour and it started on the button.
Today, changed a load of bits one by one and checked for the spark that isnt there.
Changed, ecu, map sensor, crank sensor,coil, phase sensor, ign amp, checked pin voltages all fine.
Have voltage at coil and all the right places.
What the hell is going on. I have no spark.
Any help would be very much appreciated
Old Jun 17, 2006 | 04:36 PM
Taner's Avatar
Taner
Can anyone help me.
im pulling my hair out.
I still have no spark.
Only thing i havent changed looking back is the map sensor, but im sure this wouldnt stop it from sparking.
( have 12 volts at the coil lead. Whats going on )
Old Jun 17, 2006 | 04:38 PM
Dave Henshall's Avatar
Dave Henshall
is the gap correct for the tdc sensor (white one at the bottom of the crank pulley) should be 0.6 to 0.7 mm against the lobes...
other than that, a duff ignition amp...
or some cruddy connectors on the wiring loom
Old Jun 17, 2006 | 05:34 PM
Taner's Avatar
Taner
The crank sensor gap is checked and fine.
ign amp i have changed
ecu wise, i have checked the pin resistance and voltages everywhere that i could and all come up ok.
Old Jun 17, 2006 | 06:07 PM
Dave Henshall
ecu power relay, fuel pump relay? these are fairly common, if theyve gone fooked it wont go,, does the fuel pump run when you go to click 2 on the switch...
other thing is if the donkey has been out,, a loos earth connection, what are the 2 earths like on the inlet manifold at the back at the bottom ? are these loose or corroded OR got silicone sealant around them
others to check, main body earth where the battery neg goes to the inner wing, are these nice and clean?
Old Jun 18, 2006 | 10:27 AM
escortrsmatt's Avatar
escortrsmatt
immobiliser?i had it on my car.loose/corroded connection.
Old Jun 18, 2006 | 04:11 PM
Taner's Avatar
Taner
Earths are sweet.
Car doesnt have an immob as it is a track car, also, has seperate fuel cell and fuel wiring.
Will go out now and double check the pin resistance, spoke to A1 today, reccomnded i double check again
Old Jun 18, 2006 | 04:31 PM
Taner's Avatar
Taner
Ok, just done another check.
Between pincs 3 &4 has the 300 - 1200 ohms
But no 2v when cranking
same with pins 5 &23
Have ohms but no volts when cranking.
Im so lost now.
Old Jun 18, 2006 | 11:19 PM
davecosworth's Avatar
davecosworth
IM BACK
i had this with a 2wd cosworth checked every thing but the map sensor and still had no joy as soon as i changed the 3 bar map sensor for a new one it fired up straght away
Old Jun 20, 2006 | 09:14 PM
Taner's Avatar
Taner
God bless you dave.
Changed the map sensor. She started on the button.
Carlbacciochi
24
Jun 30, 2016 04:31 PM
EoinXR3
Sep 7, 2015 05:44 AM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
ray barker
Aug 7, 2015 09:00 AM
