amal valve pipes
Old Jun 11, 2006 | 03:21 PM
3dr wixsy's Avatar
3dr wixsy
Default amal valve pipes
Normally the amal valve is situated on the front panel infront of the turbo, this means that the pipes to the turbo and actuator are pretty short, does the lenght matter at all cos i want to reposition to the other side where the power steering tank is, Thanx
Old Jun 12, 2006 | 10:42 PM
richm's Avatar
richm
yes, if you significantly lengthen the pipework (or more specifically, change the volume of the pipes) it will alter the boost characteristics.
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
mpilk
Sep 27, 2015 09:21 AM
