s2 chipped ecu
Old Jun 11, 2006 | 10:58 AM
bladend's Avatar
bladend
Default s2 chipped ecu
hello again i recently brought a chipped ecu off someone for my s2 escort rs turbo the bloke said it was a motorsport developments 220bhp chip ive stuck it straight on a standard turbo and the cars speed has not improved does the car need arolling road setup to work or is the ecu not chipped
Old Jun 11, 2006 | 11:34 AM
mathewwebber's Avatar
mathewwebber
The chip will allow you to run more boost than standard which is what will give you the extra power. Its always advisable to get the car setup correctly by professionals as they will no the limits given the state of the engine and prevent damage.
Old Jun 11, 2006 | 12:05 PM
bladend's Avatar
bladend
cheers mate ive got it booked in for a rolling road tune on the 21st of this month the engine is mint its a 1991 with a brand new turbo otherwise i wouldnt put the ecu on what do u recon i will get bhp wise then
Old Jun 11, 2006 | 12:07 PM
KSA-Cossie's Avatar
KSA-Cossie
If just a chip with no cam etc i'd say about 175 bhp.
Old Jun 12, 2006 | 12:44 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
My S2 managed 206bhp with chip, filter, exhaust, Grp A coil, with 16psi.
Then promptly melted
But deffinatly a good idea on a propper setup
Old Jun 12, 2006 | 04:13 PM
HORNETS7's Avatar
HORNETS7
your car will need the boost turning up to get more power the chipped ecu will allow it to run that extra boost !
if its all standard u will need a -31 actuator as well before getting it set u p!
14-16 psi should be ok for a standard engine but your fuel needs matching to the boost!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
griffo69
Oct 4, 2015 11:58 AM
RSmark84
Sep 13, 2015 01:29 PM
