Fitting 2WD Cooler to S2 and BHP Q
Righty. I think that i have to cut lower bar out of bumper, and remove the foam in bumper so that cooler sits in without moving rad yeah?
Ok, what about pipe work? Reverse charge carrier? Also, what pipes do i use?
Also, when this is done, will i have a lot of lag?
When this is fitted and set up what figures am i looking at tops with std head etc?
Lee..
Lee..
Krazy Kim off here now owns the car she may have some more piccy,s of it?
You can see the pipe work running along the slam panel can,t be seen when bonnet is closed
After having a quick measure i reckon a std grale cooler would fit with very slight mods giving a neater and more factory look.
heres a pace rep of the std grale cooler, the std ones are better, come in black and usually go for Ł50ish 2nd hand.
imho alot better shape for the space available and the outlets are nearly cock on for std rst hoses the only drawback is the cooler has the same size outlets as the cossie one.
the piccy is upside down for some reason
Guest
Posts: n/a
When i fitted the 4x4 cooler i ran the pipework inside the bumper cavity after i cut all the foam out, looked quite neat when it was finished, pity i havent go tthe pics anymore
i just used a couple or 3 samco 90 degree bends to avoid bending any pipework, local welders did the cooler for about Ł15
worked out quite cheap in the end.
about the same volume as a std 2wd cos one
on my grale last year at trax i measured inlet temps of 35C max no more running 1.2 bar boost for a full session
cheers mate, are they easy to find?
Originally Posted by Stu.H
lee, any luck mate?
i will be talking to karl on monday re a double 4x4 cooler setup for s2.
markk
18
Aug 17, 2015 05:19 AM
155lee
Aug 14, 2015 11:21 AM
lockie
Jul 31, 2015 10:03 PM
