Does anyone have complete list of...
Hose clip sizes for S2 RST.
After fitting boost, water and ancilliary hoses I wanna replace all the old clips.
does anyone have a list of the sizes?
measure them chap
BTW, i dontthink you can get the original clips anymore, just bland clips with no ford logo's on
I've got a big box full of clips off RST's, if you need a load, PM me sizes and quantities
small ones will be 13mm, then 25mm, 32mm, 40mm, 51mm and possibly bigger for the boost hoses however i 'think' they are 51mm but not sure
Ah just thought the header tank/turbo water feed ones might be 9mm but i doubt it!
And what is the score with the water and anciliiary set!?!
it misses out 2 water hoses (heater matrix and the other on the Y splitter) but 1 hose out of the lot is a non water hose (rocker cover to main block)! Dont understand!
Lee I got mine from cossymad for a fair price, but keep an eye out at the shows, they are a bit cheaper if u buy them on the day.
Dave, I never said I wanted ford ones, just want stainless steel ones.
I got all mine on the day at ford fair for a good price,
Tell me about it, I need to get them extra two from roosemotorsport
But now will have roosemotorsport stamped on aswell as samco
Ah well u dont see them really at the back.
Have fun fitting the rocker cover to block one mate? Did it last week, the standard one just would not come off, coont!
Got there in the end
where do u get em from dave?
adam, yeah that one is a bitch, but did u just pull it off or try and remove the clip? I tried to get the clip off which werent easy at all! And the samco ones are bigger than the originals so the clips wont go back on! - which is y Ive decided to just replace everything with new clips.
does roose have a website?
Have fun fitting the rocker cover to block one mate? Did it last week, the standard one just would not come off, coont! Got there in the end
Essex & Till, yup that is what I did, I got the clip of with my finger and mole grips, my finger was hurting! owwww
I got the clip off but it was welded, slit the side of it and bent/pulled it off.... Like u say new one goes straight on and I opted to use a jubilee clip instead, lots better
Right guys went down to burtons at the weekend and they have a list of all the clips needed. Though in stainless steel form its not cheap!!!
3 x 50-70mm
5 x 60-80mm
4 x 35-50mm
1 x 25-35mm
1 x 22-30mm
2 x 11-16mm
6 x 22-30mm
I've yet to fit em yet so I will update if anything of this is wrong.
3 x 50-70mm
5 x 60-80mm
4 x 35-50mm
1 x 25-35mm
1 x 22-30mm
2 x 11-16mm
6 x 22-30mm
Steve Escos
Oct 1, 2015 06:57 AM
SMILER258
Sep 28, 2015 09:04 AM
