Cossie Phase sensor .. how reliable are they?
just wondering of most people on here have replced theirs? are they that prone to malfunction?
also how do you gap it correctly?
is it just a case of keeping the screws loose then tightening once the sensor strip is a few mm from the rotor arm stump?
cheers
cheers
i think they are quite reliable really, no moving parts for them to fuck up only the wire
Dave,
I might be wrong on this but if yours is a T34 Es Cos then it does NOT have a phase sensor!
AFAIK the phase sensor is fitted to Small Turbo Es Cosie (Fakes
) only, they replace the conventional distributer and are VERY reliable!
Usually very reliable apart for aging burnt out wires as Gareth has mentioned, gap using a feeler gauge to 10 thou. Always worth replacing if your's has'nt been replaced since car was new.
Originally Posted by GARETH T
Doug Stirling, its called the phase sensor on a small turbo, its just not built into a dizzy
Indyrs
Dec 4, 2022 12:39 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
