escort cossie small turbo dv advice
Old Jun 7, 2006 | 08:08 PM
cossiecarl280's Avatar
cossiecarl280
Default escort cossie small turbo dv advice
GOT A SINGLE PISTON BAILEYS VENTURI DUMP VALVE ON AT THE MOMENT AND I FANCY A CHANGE. TRIED A MATES FORGE TWIN PISTON AND IT WORKED FINE. BOUGHT A GGR GRP A TODAY AND IT DOESNT WORK LOL. (WHICH I THINK IS A DIAPHRAM TYPE)
WHAT SORT OF SPEC DUMP VALVE DO I NEED?
HAS I JUST GOTTA BE A PISTON TYPE OR IS THERE ANY THING ELSE IT NEEDS TO DO. I WAS THINKING OF THIS WOULD IT WORK?
http://www.forgemotorsport.co.uk/co...roduct=FMDV004A
MANY THANKS FOR ANY HELP
Old Jun 7, 2006 | 11:32 PM
sailorbob's Avatar
sailorbob
The dump valve needs to be the recirculating type because if you vent to atmosphere then measured air isn't going into the engine and fuelling problems occur.
Old Jun 8, 2006 | 06:18 AM
Stu @ M Developments's Avatar
PassionFords Creator
Correct.
Bob, how are you getting on with your EEC dissasembly mate?
Old Jun 8, 2006 | 08:11 AM
biglee's Avatar
biglee
Audio specialist
hasnt the small turbo unit got a re-circ built on to the side of the compressor housing?
how do you get around not useing this?
Old Jun 8, 2006 | 08:24 AM
Yes it has. And i personally recomend you leave it like this.
Old Jun 8, 2006 | 10:05 AM
sailorbob's Avatar
sailorbob
Quite far but some of it is still guess work or unknown. The DCL data stuff's been hard to get my head around. TBH I haven't done much recently as I've got too much other stuff on and I think I might end up using a normally aspirated ecu ('93 Mondeo probably) for my supercharger project as I don't need a map sensor or wastegate control. Also I dislike the 'tacked on' approach Ford took with adding the extra code onto what's basically a normally aspirated ecu's code.
Old Jun 8, 2006 | 12:23 PM
biglee's Avatar
biglee
Audio specialist
STU, i have recently changed my turbo to one of these on my S1 , and i have just plumbed the re-circ valve in as i would a normal d/v.... seems to be workin well, i hope this was how it is supposed to be....
Old Jun 8, 2006 | 12:26 PM
You will be fine pal, the issue arises when you use an air mass meter which im presuming you dont have.
BOB, i have invested in teh full pro version of SCT (Im sure you know what i mean) So if i can help at all let me know.
Old Jun 8, 2006 | 01:14 PM
sailorbob's Avatar
sailorbob
i have invested in the full pro version of SCT
Mmm, didn't know SCT covered European spec ecu's. Wouldn't mind seeing it being used
Old Jun 8, 2006 | 01:17 PM
They are trying hard for us to support them and are doing quite well so far.
Old Jun 8, 2006 | 06:10 PM
cossiecarl280
wat do u recommend i do ive only just bought the car and its got that setup
Billy_RS
16
Oct 11, 2025 09:41 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
muz
Aug 16, 2015 12:57 PM
stickyslick
14
Aug 10, 2015 06:27 PM
fatboy billy
Aug 3, 2015 08:34 AM
